6.0 making strange noise when I let off on the throttle - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-21-2009, 02:53 PM
cynicel1 cynicel1 is offline
cynicel1 is starting off with a positive reputation.
If while going slow or from a stop I accelerate rapidly then suddenly release pressure on the throttle there is a loud noise from the engine compartment. It sounds like it is coming from the air intake area, maybe like a valve is slamming shut and causing the engine to choke. If I release the throttle slowly with no load on the engine this does not happen. Any ideas?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 12-21-2009, 03:00 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Sounds like "turbo fart". That's a normal sound, particularly on a cold engine, although it is louder if you have an aftermarket cold air intake. Because these engines do not have a waste gate, excess boost pressure can backflow when you let off the throttle suddenly.
Old 12-21-2009, 03:31 PM
Thanks for the response, sounds reasonable but I never noticed it before and now I hear it regularly.
Old 12-21-2009, 03:35 PM
bpounds's Avatar
2 bit Californian
Do you have the original Ford air intake?
Old 12-22-2009, 08:32 AM
Yes but I replaced the filter with a K and N filter.
99 F250 extended cab back doors won't... scottinjaxf250 1999 to 2016 Super Duty 15 08-30-2015 06:41 PM
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 08:17 PM
Lack of power xoloski Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 05-29-2012 12:10 AM
What is my trim level? ABF PSD 1999 to 2016 Super Duty 11 02-09-2012 09:26 PM
Pre Purchase Inspection AirborneCav 1999 - 2003 7.3L Power Stroke Diesel 4 03-09-2011 08:00 PM
Tags
60, clicking, duty, f150, fart, ford, gas, intake, letting, makes, noise, releasing, sound, super, throttelford, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
