1948 F-6 - Ford Truck Enthusiasts Forums
1948 F-6
Old 12-21-2009, 02:20 PM
Griff52's Avatar
Griff52 Griff52 is offline
Griff52 is starting off with a positive reputation.
Question 1948 F-6
Hi,I am buying 1948 F-6 flat bed dump,any idea on the weight of the old girl,trying to figure out if I can haul or if I need to have it shiped. Thanks
Vern
Old 12-21-2009, 02:37 PM
rb48f6's Avatar
rb48f6 rb48f6 is offline
rb48f6 is gaining momentum as a positive member of FTE.
Great another 48 F-6 with flat bed dump! Assuming you already have a trailer, do you know the trailers capacity?
Old 12-21-2009, 03:19 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Just as important as the trailer is the vehicle you're going to haul it with. From my expereince I wouldn't go with anything smaller than a heavy 3/4 ton truck. I hauled a '48 F-4 400 miles with my 1/2 ton 4X4. I would never do that again. My truck had plenty of power to get it up and going but the first time I got it up to 55 mph going around a curve it got aweful scary. I ended up going on two lane roads for 375 miles going 45 mph, it was a very long trip. I've hauled big trucks, F-5 and F-6s, behind a 1/2 ton truck plenty of times without a problem but they were all just across town or a little ways out in the country until the above mentioned F-4.
The F-6 is going to weigh a bit more than my F-4 and mine didn't have a bed on the back. All of the trucks I've hauled fit on a standard car trailer, some of them hung over the back edge of the trailer.
Some one will be along soon to give you the specific weights.
Old 12-21-2009, 04:01 PM
rb48f6's Avatar
Good point Bob, I hadn't got that far out yet. It's amazing how big these relatively small trucks get when up in the air a bit. I have a F-250 diesel / smaller trailer and elected to spend $300 to get my F6 hauled 250 miles home. I wish I would have got a pic of it up on the 3-car ramp type trailer the guy used (too nervous and excited to think about it at the time). It looked like a monster up there with the front tires sitting over his pick-up bed.
Something else that you may run into, pending your trailer width and type, is getting the rears duals to sit right on the trailer. My trailer width was off and one would have been outside the frame and one on the angle. I could have pulled one and been okay, but didn't want to open that can of worms.
Speaking of rims, you'll need to determine what type of rims you have on your truck. There are a number of posts here dealing with the Ford 2-piece rims from this era.
Old 12-21-2009, 04:11 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Quote:
Vern
I never weighed mine but I estimate between 6,000 and 6,500#
Old 12-21-2009, 04:13 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Here's the chart for a '52 F-6 which should be the same as your '48. The chart gives curb weight for both the 134" and 158" chassis. Stu
Old 12-21-2009, 04:16 PM
rb48f6's Avatar
Why didn't I think of that earlier..... my 48 F6, 158" w/b, with a 13'6" flat dump bed weighs 7,300#'s according to the title. It should give you an idea.
Old 12-21-2009, 04:27 PM
rb48f6's Avatar
Stu~
What publication did that come from? Just so I know what to keep an eye out for. I've a 52 brochure, a 48 F7/8 and 49 F7 brochure - none list curb weights. In the meantime I downloaded / saved to file the one you posted above. Thx
Old 12-21-2009, 04:29 PM
Griff52's Avatar
Thanks guys,I think I'll go with having it transported. Trailer is only rated for #7,000 and driving distance is 930 miles one way.
Old 12-21-2009, 04:36 PM
Bob - That's from the Dealer's Handbook. I've got the '52 version and Julie has a '51 version. I think her's is more complete than mine. Apparently Ford posted revisions throughout the year which her copy has. My pages are all dated March '52. Stu
Old 12-21-2009, 05:15 PM
rb48f6's Avatar
Griff52~
You'll probably rest easier in the long run getting it hauled. Keep us posted on it's arrival and this gang likes pics!
Thanks Stu, I'll have to watch for one.
Old 12-21-2009, 05:19 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is online now
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Some time ago,
I drove my 55 F-600 over a scale when it still had the old flat bed on it.
It was right at 7000lbs, same as my 3/4t Suburban!!
Cheers,
Rick
Old 12-21-2009, 05:27 PM
Griff52's Avatar
Thanks all,when she arrives I will have plenty of pic's
Griff52
Old 12-21-2009, 05:31 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
I towed my 52 F6 12' flatbed dump bed home with a 2005 3/4 ton Dodge diesel. I rented a 10,000lb equipment trailer for $60 to pick it up as I was worried about using a standard 7000lb car hauler being to small for the duals to fit as well as the weight concerns.
I only had to go about 60 miles of freeway driving and it pulled really nice. I wouldn't hesitate to pull a similar load farther if needed.
Good luck with it.
Josh
Old 12-21-2009, 05:35 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
I know nothing.
1948 flathead vs. 1948 flathead kens65fb 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-17-2016 02:33 PM
1948 6 cyl vs v-8 Jack1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-07-2015 12:45 PM
1948 ford f68 ? Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-16-2011 01:09 AM
1948 F1 Wheel Steel Rim needed 1948 F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-21-2010 11:58 AM
1948 Ford F-6 Vin Locations 63maroontruck 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-06-2009 01:09 PM
Tags
1948, 1948f6, 1950, 52, curb, dump, f5, f6, flatbed, ford, front, truck, trucks, weight, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
