Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-21-2009, 09:53 AM
Joel59 Joel59 is offline
Garage is empty, add now
Joel59 is starting off with a positive reputation.
2.5L questions
Hello. I have a 98 ranger with the 2.5 four cylinder. The timing belt broke on it this weekend. I pulled in apart and installed a new one. I triple checked the timing marks and am sure that all three line up as they should. While I had it apart, I decided to put on new spark plugs and wires. I pulled off the intake manifold and removed the vacuum lines to get at the two difficult spark plugs. After I got all finished my ranger started right up and idled well. I thought all was fixed. When I put the truck in reverse it died. Then it didn't want to start up again. I had to pump the gas to get it started again. It acts like it is loading up with fuel, as it seems like the exhaust smells like raw fuel. I also notice that the farthest fuel injector back is ticking loudly. Did I screw something up with the injector? It seems more like a fuel problem than the timing. The timing is on. What are your thoughts? Thanks.
Click the image to open in full size.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
