Dome Light will not go off.. door ajar is off - Ford Truck Enthusiasts Forums
Old 12-20-2009, 11:40 PM
moveyourcar moveyourcar is offline
moveyourcar is starting off with a positive reputation.
Ok so I have a 2000 Expedition and my issue is the Dome Light will not go off but the Door Ajar light is not lit but it does go on and off when the doors are opened and closed, Obviously the WD 40 trick isn't going to work. Anyone else know what the possible cause is behind this? Bad Relay or?
Old 12-21-2009, 01:45 AM
sixing sixing is offline
sixing is starting off with a positive reputation.
May sound stupid, but is the headlight switch **** turned all the way counter clockwise? as this turns on the dome light when doors are closed.
Old 12-21-2009, 10:34 AM
Quote:
Actually on 2000 Expedition it was not the headlight switch it has a seperate control for the dome/interior lamps and running board lamps which is also the dim controls for the cluster.
Old 12-21-2009, 11:35 AM
Oh I failed to mention I pulled the fuse for it so at night I will not get pulled over or run the battery down when it's sitting in the driveway. The bad part about this is it will not allow me to shift from Park to any other gear it's locked out and the power windows will not work. So it is becoming a pain in the *** to put the fuse in every time I want to use my windows or back out of a parking spot.
I'll be trying to replace the relay but I'd like some confirmation on what else can cause it I'm trying to avoid a dealership for the obvious reason it's out of warranty.
Old 12-21-2009, 07:07 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
See if the inside firewall area is wet around the fuse box area. Some of the trucks have a problem with the windshield leaking and getting the fuse box and the GEM module(which does all the domelight control among other things) wet and causes it to act crazy. I wonder if the expeditions have the same problem?
Old 12-21-2009, 07:38 PM
Sportruk's Avatar
Sportruk Sportruk is offline
Sportruk is starting off with a positive reputation.
Did you try the WD40 soaking of the door latch? The Illuminated Entry(Dome light) switch and Door Ajar switch are 2 seperate switches within the latch. The Door Ajar switch has never been the problem, it's the Dome light switch that causes the problem.
Old 12-21-2009, 07:44 PM
Quote:
Already checked that and wasn't wet. I also failed to mentioned I live in AZ when this happened we had not had rain for quite some time and I hadn't washed the truck recently either.
Old 12-21-2009, 07:47 PM
Quote:
Tried that with all doors and no go, any tip for it? like the location of the switch? Just really need the general area I need to hit with WD40 I got all around the latch and in the crevices as well.
Old 12-21-2009, 08:30 PM
Sportruk's Avatar
As I recall, the switch is in the upper part of the latch. The picture shows roughly where you need to concentrate the spray. You might need to partially click the latch to open the spot. Soak it well. The front doors are the more likely to be causing the problem, as this is very common in the pickups as well.
Old 01-01-2010, 07:36 PM
So gave this a try still the same issue. Like I said the Door ajar light goes off and the chime isn't on it's just the interior lights that will not go off. I've used half a can of WD40 on all latches and still nothing.
Old 01-01-2010, 09:40 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Disconnect the battery, turn on the headlight switch.
Go have coffee.
Come back in 20 min
Reconnect.
See if anything changes.
Old 01-03-2010, 11:13 AM
Quote:
Go have coffee.
Come back in 20 min
Reconnect.
So yeah tried this last night and no change.
door ajar and interior lights won't go off dmanshane 1999 - 2003 7.3L Power Stroke Diesel 4 09-29-2014 11:15 AM
2007 sport trac xlt door ajar while driving joannematta Explorer, Sport Trac, Mountaineer & Aviator 9 10-17-2011 04:02 PM
1996 Ranger dome light/door ajar BAGamble Ranger & B-Series 0 03-26-2011 02:31 PM
dome light/door ajar socalarcade Ranger & B-Series 2 12-12-2010 06:17 PM
1999 ranger"door ajar" stays on sbappleg8 Ranger & B-Series 8 06-11-2009 11:13 PM
Tags
1997, 2003, ajar, dome, door, expedition, explorer, f250, ford, jar, light, lights, truck, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
