1997 Ford F-150
1997 Ford F-150
Found this on CL, I wasnt really looking for a 1/2 ton but I figure it might be a decent deal?? How hard is it to get the heads off these engines?
Deal on 1997 Ford F-150 4WD Supercab
He says that it is in fair condition, I don't know what that means but fair isn't good and good isn't great and great isn't perfect. I do believe the way that the dealer will take the heads off is to lift the cab off the frame to get to the rear of the motor. It's probably a $1000 or more job to do both, most of which is labor of course. It is a labor intensive procedure but it is doable like anything else just depends on if you're doing the work or someone else is.
But the body from what I see in the pictures looks good.
