power window switch bezel - Ford Truck Enthusiasts Forums
Old 12-20-2009, 05:25 PM
fordfan46 fordfan46 is offline
fordfan46 is starting off with a positive reputation.
Hi everyone, I received so many informative replies regarding my cruise control issue, I thought I would ask another question. The power window switch bezel on my 2001 f150 extended cab Triton V8 driver's door is broken and will no longer lay flat. I have found one on line at www.fordparts.com. The part number they use is 14524. However this number applies to several power window switch bezels. I am uncertain as to which one I need. The interior of my truck is graphic grey. Could someone convert the web site part number to Ford's part number? Hopefully this would lead to a better description of the part.
Old 12-21-2009, 07:06 AM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
PM Number Dummy, he is the parts guru on this site.
Ford Truck Enthusiasts Forums - View Profile: NumberDummy
Old 12-21-2009, 05:41 PM
Thanks for the info; I will keep that in mind for future reference. I went to my local ford dealer and they looked it up for me. Believe it or not, it was about the same price I had seen it on the web for, so I went ahead and ordered it.
Old 12-21-2009, 08:44 PM
torkum's Avatar
More people should check with the dealerships for parts, the differences from the parts stores are usually closer than you think. I get all electronic parts from the dealer and they only a few dollars more than the off brands at the parts store.
Door panel problems renegade_75 1994.5 - 1997 7.3L Power Stroke Diesel 3 05-22-2016 11:36 PM
Instrument & Radio Bezel Info - Help Needed Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 62 04-05-2016 10:55 PM
power window switch connector dnkensinger 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-18-2015 01:25 PM
Correct COP oneminizut Modular V10 (6.8l) 2 07-12-2014 03:18 PM
Door Window Switch Bezel Replacement Linell 1997 - 2003 F150 0 09-27-2013 08:07 PM
Tags
14524, 1997, 1999, 9703, bezel, door, electric, f150, ford, power, switch, switches, truck, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
