Pennsylvania Chapter Join Chapter, Leader: liftnw8z
pa insp smog over 25 years old?
Old 12-19-2009, 06:40 PM
roadrash63's Avatar
roadrash63
roadrash63 is offline
hey
is there a pa insp for smog on a truck over 25 years old?
hoping not
merry christmas
Old 12-19-2009, 11:03 PM
PatsPOS's Avatar
PatsPOS
PatsPOS is offline
It's my understanding that anything built in 1975 and later (and UNDER 8500 GVWR? I MAY be inadvertently making that part up) needs to have an emissions inspection. And I think the definition of "emissions inspection" varies depending on which county you live in. I know in Cambria County we have a visual inspection and a gas cap test.
Now, having said that...if you get yourself a classic or antique registration, then you're exempt from emissions inspection. An added benefit to the antique registration is no more safety inspection, either!
If I'm wrong on anything, someone kindly correct me! Hope this helps...
Pat
Old 12-20-2009, 02:52 PM
roadrash63's Avatar
roadrash63
hi
in crawford county ( just south of erie ) we have no actual smog test
just the " visual inspection" of components...
i would like to junk all of it and remove the speed density efi !
Old 12-20-2009, 06:29 PM
78workhorse's Avatar
78workhorse
78workhorse is offline
I know if you put less than 5,000 miles a year you just need the visual emmision inspection.
Old 12-25-2009, 05:02 PM
Tees77f150's Avatar
Tees77f150
Tees77f150 is offline
Pat
This is correct for Dauphin county too(Harrisburg area). 1975 and earlier is exempt, and everything else is visual, with the exception of the gas cap. I opted NOT to put antique plates on my 77 as they are too restrictive to driving times for my liking. But the antique tags exempt you from a safety inspection, or emission testing too.
Old 12-31-2009, 09:33 AM
mark a.'s Avatar
mark a.
mark a. is offline
Under 5k= no inspection, not even visual. Any garage that tells you different needs to call the DOT inspection cop. Thats what I ended up doing to get to the botom of this.
Old 12-31-2009, 10:58 AM
BEAST428's Avatar
BEAST428
BEAST428 is offline
As I understand things, being that I have my PSI license. In Blair county anyway if your truck is 1975 or newer it must pass emmissions before it will pass safety inspection unless it has less than 5000 miles on it, even at that the state says that it must retain the emmission equipment(or approved replacements) that the factory installed on it to pass safety inspection. (cat conv, air pump, egr, etc). We were told at an inspection meeting that if the PA inspection laws were followed exactly that there would be no vehicle that would pass the inspection procedure. So In the end the final decision as whether to inspect or not rests with each individual inspection mechanic. Classic license is better than the antique because it doesnt have as many restrictions as per vehicle usage. With the classic there is modification restrictions for keeping it as factory stock looking on the outside as possible. My 79 Bronco cannot have classics because of the 4 inch lift and the 35s.
Old 01-01-2010, 11:12 AM
Tees77f150's Avatar
Tees77f150
I got mine registered at the beginning of November, with regular tags, and I am glad because I been really enjoying driving it, and I nearly put 1,000 already. I knew it would be fun, but not this much fun to drive!
I don't drive it in bad weather, or if the roads are crappy, melting snow etc. It sure looks like, I will surpass the 5,000 mile mark to be exempt, but thats ok too.
Old 01-08-2010, 07:12 PM
Redcat Diesel's Avatar
Redcat Diesel
Redcat Diesel is offline
The laws are the same for all counties that fall under the emission program. As BEAST428 said you have to keep all of smog equipment even your buggy is registered in a non emission county. If a PA inspection mechanic is caught removing the stuff the fines are astronomical.
I have my 72 registered as an antique. For me it's a nice deal since I rarely drive it. I also have it insured as a collector vehicle. I have full coverage for about half of what regular liability insurance would cost me. Yes there are restrictions on both but I can live with them.
Old 02-04-2010, 05:19 PM
83mike's Avatar
83mike
83mike is offline
In berks county Pre-1996 is just visual. Post 1996 is OBD2. Pre 75 or classic/antique registrations are exempt. Also you're exempt if you drive less than 5,000 miles a year.
Derrick lane
20
01-05-2011 06:33 PM
Beastmaster
11-17-2005 07:54 PM
shortleged
Ohio Chapter
07-30-2004 09:27 PM
Gobstopper909
Exhaust Systems
01-04-2004 11:35 AM
Quick Reply: pa insp smog over 25 years old?
