47 inch tires - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
47 inch tires
Old 12-19-2009, 02:42 PM
TRAINHORNMAN's Avatar
TRAINHORNMAN TRAINHORNMAN is offline
TRAINHORNMAN is starting off with a positive reputation.
47 inch tires
Found a set that i want...
selling 47 inch tires with 20 inch rims all for 700$$$$ not bad at all
good thread on them too
It is 8x6.5
how can i kno if these rims will fit..?
how can i kno if tires are too big and will rub?
Old 12-19-2009, 02:51 PM
frdf250's Avatar
frdf250 frdf250 is offline
frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.
try posting the pictures on photobucket they wont show up on here for some reason
Old 12-19-2009, 03:07 PM
still not showing up?????????
my tires now are 15/42-16.5 that means they are 15 inches wide right?
these new tires are 15.5 inches wide...but 47 tall..is that ok to get?
Old 12-19-2009, 03:23 PM
frdf250's Avatar
do you get any rub now when you crank the wheel all the way to the left or right against the leaf springs? and yes they are 15"
Old 12-19-2009, 03:26 PM
yes i do get rub... but that is because of the width right? so i should be ok.. i will be welding on the the bump stops so i dont rub..
the height should be ok too right?
Old 12-19-2009, 03:32 PM
Lizard XJ Lizard XJ is offline
Lizard XJ is starting off with a positive reputation.
47's are tall tires, and a lot of rotational mass, your going to need gearing, if it is just a mall crawler and no off road than run them. The 99 newer SD have a metric bolt pattern, 8x6.5 will not fit. You will have the deal with the offset of the rim, which is one reason why your tires rub now, Not sure what brand of tire your getting, bias ply, radial, don't know how they will balance out. Might be a rough ride, might have to lift the truck up higher to clear. It's your truck, but IMHO, 47's are to much for stock axles. Stick with 42's or go with 44's.
Old 12-19-2009, 03:37 PM
i have the early 99.... so ur sayin whoever put these rims that i have now..put on the wrong ones? thats why they rub? i thoght it was cuz my tires are just to wide?
i dont mind the rubbing cuz i will weld on to the bump stops
i dont mind the rough ride..
these tires are michelans (sp) not sure what kind tho
Old 12-19-2009, 03:44 PM
I take it military tires than. Not saying the rims are wrong, you can get different offsets in rims. in my thought you will need less backspacing which moves the tires out further away from the knuckle, extra stress on the bearings/hubs. 15" are wide tires. My new tires I am getting are 44x19.5 wide.... not on my SD though. Not sure what bumpstops are going to accomplish??? If your tires rub on the leaf springs than get wheel spacers or new rims... If they rub on the fenders well either cut the fenders and install bushwacker fender flares that open up the wheel well openings. or lift the truck up higher. just offering my .02
Old 12-19-2009, 03:47 PM
yes i appreciate ur help alot!
i do not want to lift the truck, or really get new rims..
Just saw this deal and really didnt want to pass it up.
They are military tires yes. The rim that i posted =8x6.5 this will for sure make it rub or something?
Old 12-19-2009, 03:53 PM
The newer superduty's use a metric (8x170mm bolt pattern) if I recall correctly. 8x6.5 will not fit that is a standard bolt pattern. like chevy's, dodges, older fords. I don't know what the rims came off of. What were they off of when you bought them?
Old 12-19-2009, 03:55 PM
the rims that i have now were on there when i got the truck so im not sure...
but i do have the early 99 SD does that make a difference?
Old 12-19-2009, 04:49 PM
nhill2090 nhill2090 is offline
nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.nhill2090 has a very good reputation on FTE.
no your truck is 8x170mm. They wont fit without some machining work. I have a set of 20x10 wheels im trying to sell that would look great on your truck
And weren't you the one who said you were'nt about to get big rims LOL
Can someone help me identify this wheel please, with pic GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 9 06-26-2012 12:02 PM
Finding parts - Oil level indicator/dip stick Mentadentt 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-16-2012 11:56 PM
Raising Engine and Intake manifold, 223 engine Mentadentt 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 01-26-2012 10:41 AM
My F350 Brake Booster Upgrade from a '78 F250 4x4 C6 (already power brakes) OldStyle 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-07-2012 08:28 PM
1977 F-250 4X4 or 2X4?? Discovery 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-16-2011 08:13 AM
Tags
15, 2005, 250, 40, 44x195, 47, bull, f250, f25020, fit, inch, military, pit, rims42, rockers, swampers, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
