5.4L poor intake fit and new gasket design - Ford Truck Enthusiasts Forums
Old 12-18-2009, 09:56 PM
ruiterman ruiterman is offline
ruiterman is starting off with a positive reputation.
I have my truck in the shop for Head gaskets.
The shop mentioned that another 5.4 L Ford he is working on has an issue with getting a Brand new intake to fit. The intake is such a loose fit that he can't get it to seal and it leaks coolant from the back part of the intake. He got a second new intake from Ford and it was no better. He has talked to the dealer and Ford direclty several times trying to get this resolved.
Says Ford is building the new motors with a newly designed intake gasket but that no one can get these gaskets until the old stock is depleted. The Dealer has tried to get the new gaskets and can't get them either.
He has had little to no issues in the past when he puts the original intake back on.
Has anyone heard of this before?
Old 12-19-2009, 01:41 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
You didn't say what year your 5.4 is, the only thing that comes to mind is the "power improved" engine versus the non P.I. engine. Should be obvious to him though that the port sizes are different.
Old 12-19-2009, 01:58 PM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
I'm with Ron, big difference between the 97/98s and the 99/03s.
Old 12-19-2009, 02:28 PM
thumper477 thumper477 is offline
thumper477 is starting off with a positive reputation.
Recently replaced the intake on my 01 f 150.I bought the intake at NAPA and it came with the gaskets in the box.Truck runs much better and after 1000 miles no problems yet with coolant or vacuum leaks.
Old 12-20-2009, 10:55 PM
My truck is a 2001.
However, the engine in question with the intake problem is in an ambulance and I'm not sure what year it is, or if there is a difference in the engines in the ambulance vs a standard truck. I would expect not as far as that goes, but I suppose is could even be new than an '03.
Since I'm a bit of a newbie to the Ford 5.4 L, I'm getting that there was a '97/'98 design, and a Power Improvement made in '99 on. This PI was "obviously" for more power and part of that was larger intake ports.
And it sounds like so far the people who have read this are not aware of any intake issue with the fit.
I should be talking to the Mechanic again tomorrow, so I'll see if what else he knows and if I can find out a year on that Ambulance.
Thanks,
Ed
Old 12-22-2009, 01:25 AM
The ambulance is a '97
FIXED Ford 4.9 300 cid Exhaust Manifold Leak at Head FIXED Econoline Bronco REMFLEX GASKET cordts 1968-2013 Full Size Vans 8 06-28-2015 06:33 PM
New oil pan for inline 6 momsvan89 Ford Truck Parts for Sale 4 09-21-2014 10:04 AM
Lean Issues Read Entirely nboyer71 1997-2006 Expedition & Navigator 1 04-04-2014 01:03 PM
5.4 coolant leak at the intake Superdave Modular V8 (4.6L, 5.4L) 4 06-11-2009 09:25 PM
5.4 coolant leak at the intake Superdave 1999 to 2016 Super Duty 13 06-10-2009 02:34 AM
Tags
02, 2002, 54, 54l, coolant, engine, f150, ford, gasket, head, intake, leak, problem, truck, untake, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
