Thumping noise from dash! - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-18-2009, 07:00 PM
davidstjohn1 davidstjohn1 is offline
davidstjohn1 is starting off with a positive reputation.
Ok I have a 1998 Ford Ranger XLT 4.0L automatic 4X4 with A/C my problem is i just had the timing chain,water pump, thermostat, upper and lower hoses, and front crank seal replaced. I got it back and right away noticed a thumping noise at idle only... My gauge was always steady at the same spot it had always been. but the thumping was loud when idleing. Now the sound seems to have moved farther towards the engine insted of the dash and tonight when i popped the hood noticed the top hose was collapsed and i could feel no pressure. the thumping noise seems to be comming from the area of the thermostat. I have no oil in the coolant and no coolant in my oil! I tried to get the air bubble or pocket out if thats what is the problem by rubnning the engine till hot with the radiator cap off but it made just a huge mess. it did seem to push a huge air pocket out but still does the loud thumping. This all started the day i got it back from the mechanic so im assuming its an air pocket. please let me know if anyone can help ... I planned on changing the thermostat tomorrow. Thanks in advance... Dave
Old 12-18-2009, 07:38 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Have you talked to the mechanic about it?
I would pull the T-stat and make sure it was installed in the right direction (spring-side facing the engine).
Something else to keep in mind:
Quote:
ARTICLE NO. 99-23-8
• GAUGE—TEMPERATURE GAUGE FLUCTUATION AND/OR “KNOCKING/THUMPING” NOISE FROM COOLING SYSTEM—4.0L OHV ENGINE
• COOLING SYSTEM—PULSATING COOLANT FLOW —NOISE—“ KNOCKING/THUMPING”— AUDIBLE IN PASSENGER COMPARTMENT—4.0LOHV ENGINE
FORD: 1995-2000 EXPLORER, RANGER
This TSB article is being republished in its entirety to include 2000 model year vehicles and to provide Service Part(s) and Labor Time information.
ISSUE
A temperature gauge fluctuation and/or a“knocking/thumping” noise may be audible in the passenger compartment on some vehicles. This noise is most pronounced with the engine at normal operating temperature. The noise is caused by steam formation in the cooling system. The noise is then transmitted through the heater hoses and heater core.
ACTION
Install a Coolant By-Pass Kit. This increases coolant flow which reduces steam formation. Refer to the following Diagnostic and Service Procedure for details.
DIAGNOSTIC AND SERVICE PROCEDURE
1. Check for excessive exhaust system restrictions. A restricted exhaust could elevate cooling system temperatures.
2. If dash-mounted cooling temperature gauge fluctuates, check that gauge and sending unit are functioning properly.
3. Check for restrictions or kinks in the radiator or heater hoses.
4. Pressure check cooling system for leaks.
5. Confirm proper Engine Coolant Temperature (ECT) sensor signal to EEC-V processor.
6. Check for correct 50/50 coolant mix. Verify that freezing point is -37*C (±-15*C) or -35*F (±5*F).
7. If concern still exists, install service Coolant by-Pass Kit and verify that concern has been resolved. Refer to the Application Chart in this article.
PART NUMBER / PART NAME
F8PZ-8522-AA / Coolant By-Pass Kit (‘95-‘96 Ranger)
F8PZ-8522-CA / Coolant By-Pass Kit (‘97+ Ranger)
Old 12-18-2009, 08:00 PM
Yea thats it I get a loud thumping noise bad after it reaches normal operating temp! I will try a oem thermostat sunday on my day off... My question also is how come the upper hose collapses? its like flat...Yes I did talk to the mechanic and what he was saying was to change the thermostat also. If that didnt do the trick he was going to do a chemical test to see if its the head gaskets. I really dont think for a second its the headgaskets. It started exactly after he did the work, hense air bubbles or pocket is what i was thinking. But thats why im here to get some expert opinions. Thank you.
Old 12-19-2009, 11:24 AM
!!!UPDATE!!! I just finished with the new install of the thermostat and it is now much worse and i burped it to! Maybe im not burping it right but i read here on how to burp it and its so much worse off now hmmm im stuck what to do now.
Old 12-19-2009, 08:52 PM
Rockledge's Avatar
I'm still thinking that there could be some sort of obstruction in the cooling system. That would include such possibilities as a clogged radiator, and even a bad water pump.
Why did you have the timing chain, water pump, thermostat, upper and lower hoses, and front crank seal replaced in the first place?
Old 12-19-2009, 11:37 PM
I had the timing chain done due to a coolant leak from the timing chain cover! After the timing cover was removed i discovered a very worn timing chain and gear worn also so decided to replace all of it including the front seal. I figured since i was doing that i would replace the upper and lower hoses and waterpump while i was there. One thing i did do yesterday is while idleing and it was making the thumping noise, I shut the heater off! The noise went away until i turned the heater back on then after 1 to 2 minutes the noise comes back. Also I have recently noticed that I smell a strong oder of coolant when I first start the truck inside of the cab! Oddly enough The noise stays away as long as i have the heater off!
Old 12-20-2009, 08:21 AM
matt's2.9STX matt's2.9STX is offline
matt's2.9STX is starting off with a positive reputation.
Sounds like a leaking heater core. Probably get an oily film on your windows too right? It explains the persistent coolant issues. O yeah, could just be the heater hoses too, but good idea to change the core with the list you mentioned anyway.
Old 12-20-2009, 08:35 AM
yea ty for the input.. I am gonna change the heater core asap. It seems to be just that since as soon as I turn the heater on after 2 to 3 minutes it starts!
Old 12-20-2009, 10:38 AM
Make sure & check the hoses b4 you go to all the trouble (probably fairly easy & CHEAP) of pulling the core to whether it really is the core or hoses. I'm not sure if it's easy or not on a '98. Seem to remember a lot of changes to access from 80's & early 90's setups. On our 94's, the core itself should be R&R in 1/2 hour. You will have to go through burping system again to get that air pocket out.
Old 12-20-2009, 02:44 PM
ok i will do that ty! We just had a severe storm here in Ct. So im stuck cant do anything today but i will prolly do it tomorrow if its ok outside.. I appreciate all the help so ty very much for the help ....
Old 12-30-2009, 12:04 AM
Update!!! I cant find a leak anywhere at all :-( I looked at the heater core and hoses not a single leak and even hooked up a pressure tester and it passed. The coolant level has stayed the same to! Hasent used a drop... Anyone wanna help me figure what this could be? maybe i still have a airpocket in the heater core area???
Old 12-30-2009, 08:11 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman NewEnglandHerdsman is offline
Moderatee...
NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.
I agree that it still sounds like an obstruction somewhere, and the collapsed top hose really points to the thermostat (yes, even though you replaced it already). If it's not a huge job, I'd be tempted to pull the thermostat again and check that it's good, maybe even reassemble with no thermostat to see if the problem persists. Have to ask a dumb question, sorry - you sure you put the thermostat in the right way?
Old 12-30-2009, 08:17 AM
Quote:
Yes I did put the thermostat in the right way and its not a dumb question ty for helping me. It works and keeps working as long as i dont turn the heater on i could go all day without the heater on and then turn it on and it starts within a couple minutes but only at idle. I have to leaks anywhere and have not lost a drop of coolant.
Old 12-30-2009, 08:55 AM
Moderatee...
Quote:
I'm not real familar with that truck - is there a valve in one of the heater hoses that is controlled by the heater setting? Seems there would have to be for the heater on/off to affect the noise. And if there is, being closed or open is likely to have an affect on the water flow in the pump/thermostat area... I can't make sense of that and the collapsed top hose together though... The lower hose usually has a spring coiled inside it to keep it from collapsing, but there should be no vacuum at the top hose unless there is a blockage where that hose meets the engine - which again points to thermostat... Hmmm...
Old 12-30-2009, 09:02 AM
I have replaced the thermostat last week and since then i have not had the colapsed upper hose at all! I dont know if there is a valve or turnoff for the heater? If i was to guess i would say no but im not familiar either with this truck. I can say this much since replacing the thermostat with the oem one my temp guage downt swing as much and mostly rides at normal until the airpocket hits it then it swings down almost to the bottom then goes back to the top and repeats every few minutes 2 to 3 minutes.
99 Expedition A4WD no 4HI scottb37 1997-2006 Expedition & Navigator 2 02-24-2017 08:29 AM
2011 Escape - loud noise when putting in drive silver10 Escape & Escape Hybrid 3 02-21-2013 09:12 AM
Loud thumping out of intake iron1951 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 28 09-16-2010 06:47 PM
thumping noise when turning. kystangbanger 6.0L Power Stroke Diesel 11 04-07-2009 08:47 AM
The mysterious "THUMP" TopoGeorge Excursion - King of SUVs 20 05-14-2008 10:17 PM
Tags
2008, air, core, dash, engine, escape, f8pz8522aa, ford, heater, idling, making, noise, ranger, sound, system, thumping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
