Power slider - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Power slider
Old 12-18-2009, 01:03 PM
Downriver Thunder's Avatar
Downriver Thunder Downriver Thunder is offline
Downriver Thunder is starting off with a positive reputation.
Power slider
Who wishes they had one? I think I have the wiring set up but no power window or switch. I don't have arms long enough to reach back and open the slider while driving, wish the original owner would have ordered it. lol
Old 12-18-2009, 06:18 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
TBH i would trade my rear slider for a solid glass rear window..
i literaly NEVER use the slider and would prefer teh security and no chance of a water leak at the seal of a one peice window...
but the power rear slider is dam nice to have...until it stops working... 8-(
Old 12-18-2009, 06:47 PM
SLIM_DOWG's Avatar
SLIM_DOWG SLIM_DOWG is offline
SLIM_DOWG is starting off with a positive reputation.
I do not see any reason why the the powered version would not fit. I did that modification on my previous Dodge 3500. The dodge power window upgrade was a bolt on fit. Run a power wire from the battery and you are set.
Almost anything can be done, depends on how eager you are to GIT R DONE...lol
Old 12-18-2009, 07:02 PM
VTX1800rider's Avatar
VTX1800rider VTX1800rider is offline
VTX1800rider is starting off with a positive reputation.
I have one and I'm almost afraid to use it. When I bought the truck this past spring, I tried it and it barely opened all the way. You could hear it strain. I blew out the track clean and sprayed some WD. It still had somewhat of a hard time. I clean it out again to be sure and sprayed white lithuim grease on the cable and track. Besides the interior smelling a little, it's a little better but still not to my liking. I'm not sure how to completly take it apart for a total lube job
Old 12-19-2009, 06:49 AM
Your motor is probably a little tight from not being used.
Old 12-19-2009, 09:44 AM
Quote:
Any links or write ups on how to free it up?
Old 12-19-2009, 11:36 AM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
I use my rear slider all the time. It is a great way to air out the cab. The window needs to kept clean and any debris kept out of the seals. I also spay some silicone into the seals to keep them lubed up. It helps the window slide easier and the silicone does not attract dirt and grime.
Having the extended cab without a motorized rear window in my last truck I would never open it. It was too far to reach and a pain in the rear.
Old 12-21-2009, 01:59 AM
JKBrad's Avatar
JKBrad JKBrad is offline
JKBrad has a great reputation on FTE.JKBrad has a great reputation on FTE.JKBrad has a great reputation on FTE.JKBrad has a great reputation on FTE.
I use mine all the time when backing up to a trailer and also at the boat ramp.
Old 12-21-2009, 01:53 PM
PERFORMANCE RED PERFORMANCE RED is offline
PERFORMANCE RED is starting off with a positive reputation.
I ordered my super cab with the standard rear windown because I want to put in my own power slider but with the things I have read I don't think this will be one change I will ever make.
Old 12-21-2009, 05:02 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
I have a solid glass, would like to add a power slider but cant justify the cost.
2013 power rear slider width Vforce 1999 to 2016 Super Duty 0 06-16-2013 05:49 PM
Pwr Window Cable/Slider Mech Replacement ed2hess 1968-2013 Full Size Vans 23 01-07-2011 02:08 AM
Park Assist and Rear Power Slider Problems Talonman 2004 - 2008 F150 0 09-06-2009 09:37 PM
Power rear window slider? DCH614 1999 to 2016 Super Duty 5 02-23-2006 04:51 PM
Power slider alfie623 1999 to 2016 Super Duty 20 12-14-2004 08:07 AM
Tags
150, 2000, 2008, back, change, diagram, f150, ford, howto, leaking, power, rear, slider, sliders, truck, window, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
