Type of power steering fluid?
Old 12-17-2009, 08:57 PM
ashleymc's Avatar
ashleymc
ashleymc is offline
Whats the proper fluid for 05 4.6 power steering unit ? I see the fluid while engine is bouncing up and down a little so looking closer i see a min and max line..seems to be bout 1" below min. dont want to put wrong stuff in..thanx
Old 12-18-2009, 07:01 AM
Djack04F150XL's Avatar
Djack04F150XL
Djack04F150XL is offline
You can use Mercon V fluid with no problem.
Old 12-18-2009, 09:30 AM
Gearbanger 101's Avatar
Gearbanger 101
Gearbanger 101 is offline
Indeed. In the past it was necessary to run Type F in the power steering fluid reservoir, but the current brand of Mercon V is fully compatible with your system.
Old 12-18-2009, 06:52 PM
ashleymc's Avatar
ashleymc
ashleymc is offline
followup
Advance Auto Parts sold me their brand DEX 3/M and it states suitable for trannys requiring Dexron3 and Mercon..no V or 5 after the Mercon..so i guess its the wrong kind?? Shold it state Mercon V ??
And should this resevoir be topped off cold or warm ? Engine running or not??
thanks!!
Old 12-19-2009, 07:04 AM
Djack04F150XL
I keep mine between the min/max line when its is hot. About every other oil change I use a suction gun to remove as much as I can get out and top it off with fresh fluid. I am not sure but the recommended fluid may be regular Mercon But I prefer Mercon V because it is synthetic.
Old 12-19-2009, 07:44 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
look in your owners manual it should say Mercon/atf
Old 12-19-2009, 09:29 AM
ashleymc's Avatar
ashleymc
ashleymc is offline
Smile re
guess its ok to use what i got.. just Mercon
Good tip about sucking resevoir dry before refilling!!
Old 12-19-2009, 10:02 AM
powersmoked
+1 on removing some fluid from power steering at oil changes. I bought a turkey baster for $1.25 and i use that you can attach a hose to the end of the baster and get it down to the bottom of the pump to suck even more out.
Old 12-19-2009, 08:51 PM
06F150Guy's Avatar
06F150Guy
06F150Guy is offline
My 06 5.4 4x4 says use Mercon V in the manual and on the top of the dip stick it says Mercon V make sure you don't mix the 2!!!
Old 12-19-2009, 09:02 PM
ashleymc's Avatar
ashleymc
ashleymc is offline
mixup
my man states mercon..no V after it..reads ok for power steering but mercon V for tranny required..now im wondering as i put in just mercon no mercon V
Nothings ever easy with newer trucks..gimme back my 86 f-150 4x4 anyday..$11,000 delivered
Old 12-19-2009, 09:15 PM
ashleymc's Avatar
ashleymc
ashleymc is offline
yeah it does say..
dont mix mercon and mercon V very boldly in my manual..i guess warning more for trannys than power steering..somebody posted above stating mixing the two was ok, as one was synthetic..(why do i hear a ching ching noise)
mattymax
1999 to 2016 Super Duty
10-16-2016 04:15 PM
Blackexcursion
10-05-2016 02:16 PM
Etzcutter
10-05-2015 09:33 PM
wicat3
15
09-24-2012 06:20 PM
fred_79f250
General Automotive Discussion
05-06-2007 10:57 PM
Quick Reply: Type of power steering fluid?
