New Process 435 ~ NP 435 Clutch Question - Ford Truck Enthusiasts Forums
Old 12-17-2009, 06:50 PM
Introyble Introyble is offline
Introyble is starting off with a positive reputation.
Thanks for your help in advance ~
Bought a costumed out F150 ~ Big Block with a manual 4 speed NP435 tranny.
Super nice 4x4 if only I could get the clutch issues worked out.
What the person who I bought it from (who inherited it) told me is that the transmission was out.
Turned out to be a lock up shift top and damaged shift forks ~ missing the inserts.
I replaced the slave cylinder since it was external and he had receipts for a recent master cylinder replacement from a reputable Auto Repair Shop.
Still it's a monster to shift with the motor running (easy without motor running) will barely go into 2nd (I never use the first) when at a stand still. Grinds reverse every-time.
I can pump the clutch and give it longer than normally when the pedal is depressed with inconsistent results. When I bleed it out it seems to do better for a day or two then right back to the same thing.
Also, there is more clutch when the motor is not running. As soon as you start the truck the pedal is much softer, feels almost as one of the cylinders are gone.
What am I missing? Are the plates gone or nearly gone. There is no throw out bearing noise or clutch odors to indicate this.
Old 12-18-2009, 02:22 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Are you leaking fluid?
If not, you just have to bleed the master (off the truck - a hassle) and slave better or replace the slave cyl. Basically the procedures listed in the Explorer forum apply to any hydraulic clutch set up.
I didn't know NP435s came with a slave cyl.
If you have a NP435 then granny low and reverse are not synchronized and will clash if you have a misadjusted clutch, hydraulic or not.
If you have a NP435 there should be an inspection plate at the bottom of the bellhousing, wear safety glasses and look inside to see if the disc is worn.
Old 12-18-2009, 04:24 PM
I am starting to wonder if the shop he took it to matched the master with the OEM normally found on that year truck. It would of been orig a 302 with a manual T5 perhaps , not sure on that.
If they undersized the master by incorrectly putting a t5 master rather than a np435 master ~ could this explain what I'm seeing? Surely the two masters are not the same ~ or maybe they are?
1976 f150 390 and np435 tran clutch clicking collinrandle 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-02-2015 05:47 PM
NP 435 grinds gear in 2nd to 3rd shift hooperdoski 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-07-2013 10:55 AM
need np435 experts! boggin79ford Clutch, Transmission, Differential, Axle & Transfer Case 9 10-11-2012 11:45 PM
np435 hard to shift warm 4onfloor Clutch, Transmission, Differential, Axle & Transfer Case 4 05-02-2011 07:41 AM
NP435 front seal leak captbly 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-06-2001 12:15 PM
Tags
435, bearing, clutch, cylinder, fork, hydraulic, installation, np435, pedal, process, replacement, shift, slave, throw, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
