abs light/overdrive light
well hay all,i have a 2000 ranger about 4 months the abs light came on, i checked the front brakes and replaced them, i did not check the back, the light is still on ,now today i was driving it when the overdrive light starting blinking, do you think one has anything to do with the other, i am going to go get the codes checked friday, any help would be GREAT,thanks 2000 ranger 3.0 with 145000,miles
You might consider a faulty rear ABS speed sensor (the one mounted on the rear differential). Not that expensive and easy to replace.
Another condition that can cause similar symptoms is a moisture-laden 40-pin harness connector located under the drivers seat. See: Ford Truck Enthusiasts Forums - View Single Post - 2000 Ford Ranger Overdrive light flashing
I actually bought the AZ one a year ago it lasted about 3 months. it cause some frustration to figure it out. I replaced it with another az one and that has been fine for about 6 months. If it happens again I am just going to get the best one i can find. Motorcraft if they make it.
ibew481
1983 - 2012 Ranger & B-Series
07-13-2016 10:19 PM
Geomin
40
07-24-2015 11:39 PM
