! HELP ! PCM Removal Trouble - Ford Truck Enthusiasts Forums
Old 12-17-2009, 04:53 PM
Automator's Avatar
Automator Automator is offline
Automator is gaining momentum as a positive member of FTE.
I am trying to remove my PCM to check the code from the truck in my sig ('01 dually) and cannot seem to get it out. I have the connector off (long connector with single bolt in center) and the two 7mm bolts on the plastic housing. The housing and the module will move about 1.5" and stop. Is there anything I am missing to get this out!
Old 12-17-2009, 05:00 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
You may need to pull it towards the right a little to get it to come out.
Old 12-17-2009, 05:03 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Are you talking about the the long bolt with plastic housing under the hood??? I know you have to disconnect the multi pin connection under the hood?? Its been a year since I pulled mine but it was a bugger to get out, manuvered it around a bit until I got it. But wait till others respond first, forget how many bolts there is.
Automator's Avatar
Thanks, I just did a search and found a video and am about to go back out and try it
Old 12-17-2009, 05:12 PM
USAF CCM's Avatar
USAF CCM USAF CCM is offline
USAF CCM has a good reputation on FTE.USAF CCM has a good reputation on FTE.
Don't forget to pop out the two plastic push tabs/pins/screws that hold wiring harnesses to the PCM cover under the dash. It does take some maneuvering to get it out.
Old 12-17-2009, 05:30 PM
Automator's Avatar
OK, I just didn't "tug" it enough to he right, had to move a cable that wa in the way as well. I got the code (PMT2) and it's all back together, started up and ran fine. The video I found in the seardh helped as well Diesel Movies - I install a DPTuner F5 chip in my buddies truck. Positions were Stock hi idle 60tow 80econo 120 race 140smoke.
Now it's time to get hold of Tony!
Old 12-18-2009, 01:24 PM
westpsd westpsd is offline
westpsd is starting off with a positive reputation.
You are lucky. The PMT2 is the preferred PCM for most of the tuners. I had to buy one to replace my early 99 PCM Tony will be happy!
Jim
Old 04-08-2014, 12:27 AM
cmbudin cmbudin is offline
cmbudin is starting off with a positive reputation.
Question
Does any one know if you have to take the clutch petal out of the way in order to get the pcm box out? I have tired to get it out but there is no room to go to the right with it because the clutch is in the way.
1999 7.3 f250
Old 04-08-2014, 12:50 AM
jps47's Avatar
jps47 jps47 is offline
jps47 is starting off with a positive reputation.
Quote:
1999 7.3 f250
No on removal, but keep the metal mount on the pcm and take them out together or you can have someone push clutch in
Old 05-10-2014, 11:14 AM
FarmingF250's Avatar
FarmingF250 FarmingF250 is offline
FarmingF250 has a good reputation on FTE.FarmingF250 has a good reputation on FTE.
1999 7.3 f250
No clutch pedal removal required. Removal bolt under hood and pull cable connect apart from under hood, remove two screws from plastic cover and the whole thing should slide out backwards. If you unbolt the entire metal frame (two more screws) it is a little harder.
Old 05-10-2014, 06:13 PM
landmobile's Avatar
landmobile landmobile is offline
landmobile has a good reputation on FTE.landmobile has a good reputation on FTE.landmobile has a good reputation on FTE.
And remember to disconnect both batteries before loosening up the PCM electrical connector.
Old 05-11-2014, 05:28 AM
HKusp's Avatar
HKusp HKusp is online now
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Quote:
Not necessary. Just don't fool around with it and the key in the ignition. I have taken my PCM out and put it back many times with the batteries hooked up.
Old 08-15-2014, 03:45 PM
BeachEx's Avatar
BeachEx BeachEx is offline
BeachEx is starting off with a positive reputation.
Ok, trying tothanks
PCM Diagram FourDead 1994.5 - 1997 7.3L Power Stroke Diesel 0 07-07-2016 11:08 AM
TS chip can't start tjbradney 1999 - 2003 7.3L Power Stroke Diesel 4 04-16-2016 03:59 PM
How do I remove the under-dash PCM? truckfella 1999 to 2016 Super Duty 8 11-12-2014 05:02 PM
pcm connector bolt riverking 1999 - 2003 7.3L Power Stroke Diesel 7 08-04-2014 11:33 PM
"Why is truck trying to stall/quit out on me?" hunter301 1999 - 2003 7.3L Power Stroke Diesel 59 04-04-2014 08:54 AM
Tags
1999, 2001, 2003, 73, control, f250, f350, ford, located, module, pcm, powerstroke, powertrain, removal, sale, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
