460 Headers for 77 F-250 4X4
Guest
Posts: n/a
I have a 77 F-250 4X4 with a 400M and am going to swap to a 460. I have done this before in another truck and used L&L products fenderwell Headers and motor mounts. The problem is that the mounts are priced OK but the headers are about $500. They are a very good set of headers but a little spendy for this project. Does anyone here know of any other companies that make headers for this swap. They need to be fenderwell headers as I want the extra room inside of the frame. I thought that Hooker used to make a set but haven't been able to find any info on them.
Thanks ahead of time for the info.
>swap to a 460. I
>any info on them. Thanks ahead
i'm just finishing putting together my 1977 f250
4wd with a 460 and i'm using hooker competition
headers. they still are about 500.00 though.
but check out www.autokrafters.com has them. they
have alot of stuff.
>swap to a 460. I
have alot of stuff.
the best thing for you as far as cost and simplicity is to go to a muffler mantion. become real good buddies with the garage gurue, and ask him to get a piece of sheetmetal and cut it to fit your heads, drill holes for mounting, cut holes for exhaust, and weld pipes to the sheetmetal, run the pipes to a collector, and hook em up to exhaust. it may sound complicated and pricy, but i guarentee it can be a rather simple procedure, given simple cutting, welding, and pipe bending tools... and done under 200 bucks anyway. so what if they dont have a name brand stamped on the side of them.. mine work very well on my HEMI cuda... (actually the hemi was replaced with a 440 a long time before i got the car.)
goodluck dude
goodluck dude
I put a 460 in my 79 Bronco. I didn't want to pay that kind of money to L&L either. There is a place in Washington State that was listed in the back of 4 Wheel & Off Road by the name of Stan's Headers. I bought a set of tri-y, industrial chrome headers for about $285.00. You can give thta a try
alone and unafraid
21
02-20-2019 05:25 PM
Bulldog187th
07-11-2016 07:34 PM
Blown 331
04-14-2015 09:10 PM
gingerbreadmaniac
06-21-2009 02:02 PM
