7.3 won't start; fuel problem? - Ford Truck Enthusiasts Forums
Old 12-17-2009, 01:37 AM
cowboy51 cowboy51 is offline
cowboy51 is starting off with a positive reputation.
I have an 89, F250, 7.3. I think it was running out of fuel on the front tank right after starting, although wasn't quite on Empty, and switched to rear tank, but ran rough, died and started hard...like it was loading up on fuel. Got it home, now will start, but dies right away, like no fuel. When I switch tanks now from front to rear, the fuel gauge doesn't change anymore. It just started doing that with the problem. I tried to tap on the fuel solenoid in front of the front fuel tank while a buddy switched the tank switch back and forth to see if it was stuck, but didn't hear anything. Any ideas???
Old 12-17-2009, 03:46 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Due to a problem with the fuel pickups in the tank breaking off at 1/4 tank you are lucky to get that low....... so yours may be ok in that respect.
You could have air in the injection system..... symptoms are it starts, then quits with a hard restart......
visit..... Ford diesel 6.9 7.3 IDI do the clear hose test. Any fuel leaks on the fuel filter or return line orings, actually anywhere on the fuel system.
Old 12-17-2009, 05:43 AM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
If you can't hear it switching tanks I would start with fuses. You should put a few gallons in the other tank and run a pressure and volume test at the schrader valve.
If it starts for a few seconds and dies then hard to start but runs good when it finally starts it is usually in the return lines, if it continues to run bad and dies it is usually in the fuel delivery somewhere.
Old 12-17-2009, 05:55 AM
Cowboy another thought what is the temps where you are.
Old 12-17-2009, 09:33 AM
It's cold now, but was mild when the problem occurred, so ice in the line wasn't the problem. My first concern is why the fuel gauge doesn't change when I switch tanks. Where is the fuse(s) for the fuel system?
Old 12-17-2009, 07:38 PM
Earlier, the fuse for the auxiliary fuel tank was blown, but I had replaced it with no difference. Is there any other fuse besides the block to the left of the steering column? What would be the symptoms if the tank switch solenoid in front of the front fuel tank was bad? That's what I'm guessing, but would that also cause the fuel gauge not to change between tanks?
Old 12-18-2009, 10:31 AM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
With KOEO you should be able to hear a faint ziiip when you change the fuel switch. If the tank switch solenoid is bad it won't change the gauge either. The fuse for the fuel switch is in the under dash box to the left of the steering column, I don't recall wich one it is. If the fuse is good and you can't hear the zip sound when you change the switch the tank change valve could be your problem. I was lucky enough to have 2 go bad on my 85 in about 3 months. When I got my first one from the Ford dealer the parts guy said that they had never sold one, the second one was warrenteed.
Old 12-18-2009, 12:35 PM
Funny Farmert when I was running my shop I changed countless ones on chevys but now that you mentioned it I can't remember changing one on a ford, and they are probably built in the same place. Different specs probably.
Old 12-19-2009, 06:47 PM
Diesel Fiend Diesel Fiend is offline
Diesel Fiend is starting off with a positive reputation.
When is the last time you changed your fuel filter? If you sucked some crap up from the empty front tank, you may have plugged it up gunk and need to change out the filter before you destroy your lift pump. I don't usually hear anything when I switch tanks either, but then again the truck is usually running when I do that. As far as the fuel gauges, I have the same problem, but that's because both the senders in the tank are screwed, I can only tell when my rear tank is almost empty as the needle starts to bob around a little.
Old 12-21-2009, 12:41 PM
salewit salewit is offline
salewit is starting off with a positive reputation.
Oops... sorry delete.
Old 12-27-2009, 02:26 PM
I ordered a new fuel tank selector valve from Advance (first ordered one from AutoZone, but had the wrong terminal type, so returned it, then checked online at Advance, and looks like the same valve as AZ, but has a different terminal end to change on the wiring) but then checked the voltage at the switch and it's getting 12v, but unhooked the connector at the valve and don't get any voltage at any of the slots. Is there an inertia switch, relay, or another fuse between the dashboard tank switch and the valve on the frame? Don't want to go to expense of the valve, if that's not the problem. '89 f250, 7.3 diesel
Old 12-27-2009, 04:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Key on and power will be on position 2 or 3 depending on which way the tank switch is turned.
Read this post, it will answer many of your questions.
http://www.ford-trucks.com/forums/91...el-gauges.html
Old 01-15-2010, 10:46 AM
I plugged the new selector valve into the terminal and now the fuel gauges work, so I think the valve was the problem. Now I need to hook up the fuel lines to the valve, but the Ford lines don't hook up to the valve lines (new valve made by AC Delco). Directions say to cut the fuel lines and put gas tubing over line with clamp, but with plastic fuel lines, I'm afraid it won't hold. How do you connect the Ford lines to the new selector ports? Looks like the AC valve is the same as the Pollack valve I've heard of. Will gas tubing work for diesel fuel to connect to the valve. Does anybody carry adapters to connect Ford gasline ends to fuel hose (connect to Ford end with a barbed nipple to connect hose to)? Does the diesel have too much pressure at the valve for gas hose?
Old 01-15-2010, 11:03 AM
It is sucking there on the suction side not much pressure but my vote would be to get the correct valve as every splice you have is just another place to have air problems.
Old 01-15-2010, 07:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
its all low pressure.
the IDI (InDirectly Injected) engine,just uses a low pressure fuel system from tanks to the IP pump.
simply strip back the outer layer on the stock lines.strip it back a good 4-6 inches,then your fuel line will slide right over it.then just clamp it.-dont over tighten,just enough to hold it good.
she wont leak.
if your worried about air intrusion,install an electric pump and put that old common IDI problem behind you.
Drawing fuel from both tanks simultaneously jb10725 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 10-14-2014 09:05 PM
7.3L Powerstoke Tank Switching Problem jjpski 1994.5 - 1997 7.3L Power Stroke Diesel 1 05-07-2014 04:07 PM
Truck won't start and bad fuel problems... help! os2firefox 1987 - 1996 F150 & Larger F-Series Trucks 0 11-22-2013 10:36 PM
1995 F250 Diesel Fuel System problems DonnieG 1994.5 - 1997 7.3L Power Stroke Diesel 13 01-10-2009 10:52 PM
Rear fuel tank doesn't pump, 87f150xlt 1987 - 1996 F150 & Larger F-Series Trucks 15 11-09-2004 01:19 AM
Tags
73, 89, changed, cold, filter, ford, fuel, hard, idi, low, pressure, problems, start, starting, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
