351W runs smooth then rough
Old 03-27-2000, 08:15 AM
Gatewood1's Avatar
Gatewood1
Gatewood1 is offline
77 F-150 with a 351W. It runs smooth then suddenly runs rough with no power and backfires through the exhaust. I have replaced the carb and all connected, distrubutor, plugs, wires, breather, vacuum hoses, fuel lines and filters. It will run smooth and then rough, then smooth with no particular pattern. It does the same thing either driving or sitting. What else could it be?
Old 03-27-2000, 12:48 PM
Ol' Blue
Guest
Posts: n/a
Here's a thought, could it be a fuel pick-up problem. Maybe trash in your tank? I had a miss problem with my 351M. It would run fine cold but miss when it got warmed up. Turns out it needed a tune up (bad condenser). A few people thought maybe I had trash floating around in my tank since my truck is a 74 model year. A tank that old could have alot of dirt in it. Anthow it's just a thought. Good luck.
Mark
Old 03-27-2000, 04:55 PM
Road Rage's Avatar
Road Rage
Road Rage is offline
Have you checked your timeing?I have a 80 f250 with a 351m that did the same thing.Bring any cylinder up to tdc then turn the crank backwards and watch your rotor when your rotor starts to move stop and look at your timeing marks. If the crank moved more than 7 degrees your timeing chain is shot or (or it might have allready jumped). Good Luck (Did you triple check your fireing order on your plug wires)
Old 03-27-2000, 07:46 PM
biggdave's Avatar
biggdave
biggdave is offline
get ya some carb cleaner and go around the intake maoifold, carb, and anything that sticks out. I just did battle with one of those
Old 03-27-2000, 07:49 PM
biggdave's Avatar
biggdave
biggdave is offline
part two..............look for a vacuum leak
Old 04-28-2000, 10:21 AM
kegler's Avatar
kegler
kegler is offline
all of the above is certainly good advice, if all else fails try to check your oil pressure gauge as the problem is occurring. Mine was doing the same thing, turns out the oil pump was seizing and the distributor gear pin was bending causing a timing backfire. I had noticed a needle fluctuation on my oil gauge but figured it was just the sending unit. WRONG!!!! Jim....
Old 04-29-2000, 11:49 AM
crane292's Avatar
crane292
crane292 is offline
Hey man, I have been having the same problems for about a week or so. I changed the distributer and all that too. But on mine, when you unhooked the vacum advance, it ran a little better. Is that the case? If so you might want to trace your wires down from your distributer to your ignition box on the fender well. because when i did my wires were brittle and some of the coating came off and they grounded together and it ran horrible. Unhook your vacum advance and see what happens. let me know if that's what's wrong
Mitch from Texas
Crane510(No Email Addresses In Posts!)
crane292's Avatar
crane292
crane292 is offline
Mitch from Texas
Old 05-01-2000, 08:51 PM
jowilker's Avatar
jowilker
jowilker is offline
Old 05-02-2000, 10:16 AM
Gatewood1's Avatar
Gatewood1
It ended up being the ignition module after aeverything else. Now it runs great! Thanks!
Old 05-02-2000, 10:18 AM
Gatewood1's Avatar
Gatewood1
It ended up being the ignition module believe it or not. A $20 part after all that.
70T351W
12-29-2008 09:24 PM
TrickyFrenchman
10-26-2008 11:43 PM
dkilventon
1978 - 1996 Big Bronco
07-09-2007 07:41 PM
balingwire
04-29-2003 09:07 AM
mgm415
12-10-2001 06:06 AM
Quick Reply: 351W runs smooth then rough
