How do you disconnect brake cable from parking brake assembly - Ford Truck Enthusiasts Forums
Old 12-16-2009, 06:19 PM
Tangmus Tangmus is offline
Tangmus is starting off with a positive reputation.
I am swapping out my parking brake assembly on my 99 f250 superduty...how do i disconnect and reconnect the brake cable to the new assembly? Thanks
Old 12-17-2009, 12:46 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Not having one in front of me, I will tell you how to do it for 80s/mid 90s.
Usually the nut is too rusted in place and the only way is to loosen the parking brake assembly.
If yours can be freed up, hold the cable with a 5/16 wrench while undoing the nut. My experience is you can never get enough slack to totally remove the cable. Get as much slack as you can, take the parking brake off as much as you can, twist it to the side, pull on the cable end with a needle nose vise grip, and pull the ferrule out enough to clear the swinging bracket end.
Now, if you can, you might be able to remove the cable itself from the bracket. They sell a special tool to hold the crimps down, but, this method works too. Get a small clamp, put it over the cable and squish down the fingers, slide it through the hole enough so the fingers clear, loosen the clamp enough that it will slide as you push the rest of the cable through.
You do NOT want to remove the cable itself from the floor, you will most likely mess up the rubber seals and such. You should be able to get enough slack by pushing the cable housing into the truck, to help remove the inner core from the parking brake bracket.
Old 12-17-2009, 03:53 PM
Thanks for the response. I just had this emergency brake assembly replaced less then a year ago...this one failed within that year..out of warranty with the dealership. So I am ordering the OEM part myself and doing it. All the parts and hardware are pretty new, so it shouldnt be rusted. Thanks again
dumb parking brake question Rusty 57 1957 - 1960 F100 & Larger F-Series Trucks 8 09-08-2016 10:25 PM
disconnecting parking brake cable Mark VII 1999 to 2016 Super Duty 7 08-09-2015 10:29 PM
Parking brake issue SGnAZ 1999 - 2003 7.3L Power Stroke Diesel 6 01-09-2015 04:24 PM
Need help with parking brake cable replacement!! hunter301 1999 to 2016 Super Duty 8 11-12-2014 08:58 PM
A tale of a snapped parking brake cable and massive corrosion found in suspension vze2sgxa 1997-2006 Expedition & Navigator 3 12-22-2008 12:17 PM
Tags
08, 1999, assembly, brake, break, cable, disconnect, emergency, f150, f250, ford, parking, release, replacement, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
