Explorer 8.8 swap in a 53 - Ford Truck Enthusiasts Forums
Old 12-16-2009, 03:44 PM
chappys4life's Avatar
chappys4life chappys4life is offline
chappys4life is starting off with a positive reputation.
Okay I see that the 8.8 from an explorer is a good fit for a 53 f100. I think I have located one with drum brakes on good condition locally. My question is what do I need to do to install it into my truck?
Old 12-16-2009, 04:27 PM
jaye's Avatar
jaye jaye is offline
jaye is starting off with a positive reputation.
I grounded the spring perches off and welded on new ones, I got the U-bolts & spring tie plates for the shock mounts. You will only use those f you are putting the axle on top of the springs, I also got the e-brake cables & pedal, it mounted witha little modification. I also got the drive shaft from the Explorer.
Old 12-16-2009, 04:46 PM
rtcalabrojr's Avatar
rtcalabrojr rtcalabrojr is offline
Darksider
rtcalabrojr is starting off with a positive reputation.
Jaye hit it on the nose!! I have the same but in disc brakes!
Old 12-16-2009, 05:30 PM
3golfjack's Avatar
3golfjack 3golfjack is offline
3golfjack is gaining momentum as a positive member of FTE.3golfjack is gaining momentum as a positive member of FTE.
I left my Explorer 8.8 rearend under the leafsprings. Moved the shock mounts to the front and kept the stabilzer bar in the rear. I still need to remove the old mounts. I got the leafsprings from Speedway, they have a reverse eye on one end.Got the u bolt kit from Midfifty.
[/IMG]
Old 12-16-2009, 06:38 PM
1PieceAtATime 1PieceAtATime is offline
1PieceAtATime is starting off with a positive reputation.
he he he ... looking at an ABS sensor on the top of the diff under a 1950's model truck....
Super cheap parts, no availability problems, and any ratio you could want, locker, non-locker, drum, disc, anything. For what it's worth, I think thats a great idea ! You don't have to use the $20 a quart synthetic fluid, btw, as long as you flush it all out 80w90 works fine. You lose a .025 mpg fuel economy savings as well as the 100K service interval, but $3/qt.
Old 12-16-2009, 07:21 PM
rastiss's Avatar
rastiss rastiss is offline
rastiss is starting off with a positive reputation.
i am looking at a '96 explorer for my "donor" running gear. i found 2 @ salvage with 5.0 and auto and disc rear. both are 150,000 + on mileage. that kinda scares me a lil. the torsion bar frt end would be a thought since it has rack and pinion too. the beauty of explorer is there are a LOT of them for parts. some of the '96's also had cast iron gt-40 heads instead of the gt-40p. so header should be easierto do. lower intake was also gt-40ish as i remember. i sold an engine a few years back out of one and now i wish i hadnt.
Old 12-16-2009, 07:32 PM
nordvik72's Avatar
nordvik72 nordvik72 is offline
nordvik72 is new and has a neutral reputation at this point.
Or you could buy a four link setup and everything you need will be in a package and you get to ditch those leaf springs for coilovers or bags.
Old 12-16-2009, 07:38 PM
Darksider
Quote:
LIke MEEEEEE
Old 12-17-2009, 04:25 PM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
Quote:
Jaye,
What year EXPLORER rear end is yours? Are you gonna mount the e-brake pedal in place of stock parking brake. Thanks
Old 12-17-2009, 04:41 PM
Darksider
Jaye looking at your pic it looks like you have a big pinion angle?
Old 12-17-2009, 08:13 PM
jaye's Avatar
Donald this is a pic of the e-brake pedal & it's a 94 Explorer; Roger the pinon wasn't set when the picture was taken.
Old 02-14-2010, 05:37 PM
tacson's Avatar
Jaye,
Have another question for you. You going frame mount or firewall mount with your brake master cylinder and booster?
Old 02-16-2010, 05:54 AM
jaye's Avatar
Donald it's mounted on the firewall you can see a little of it in the pic below; its from a Ford Ranger.
Old 02-16-2010, 07:39 AM
mt54's Avatar
mt54 mt54 is offline
mt54 is gaining momentum as a positive member of FTE.
I used a 8.8 out a exsplorer. used the exsplore springs and ford ranger hangers. I had to shave the hangers to narrow them to fit the perches on the rear end.
Old 02-16-2010, 07:57 AM
Lakotas53's Avatar
Lakotas53 Lakotas53 is offline
Lakotas53 is starting off with a positive reputation.
I did mine just like Jaye. Easy swap. 96 explorer drum brakes, pics in gallery.
2004 explorer rear axle ? nussford Explorer, Sport Trac, Mountaineer & Aviator 3 07-26-2015 11:04 PM
Explorer 8.8 Rear End dferrell5 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 01-25-2014 02:26 PM
What rear Springs??? big schott 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 01-25-2014 01:11 AM
Will an 8.8 fit in my 1965 F100??? Waylon Fan 1961 - 1966 F-100 & Larger F-Series Trucks 16 09-01-2012 03:11 PM
8.8 installation for 1948 F1 48flthdf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-22-2012 09:56 AM
Tags
1950, 1956ford, 88, 88rearend, 89, brakes, drum, explorer, f1, f100, f150, ford, rear, rearends, spring, swap, www53fordtruckcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
