Explorer 8.8 swap in a 53 - Page 2 - Ford Truck Enthusiasts Forums
Old 02-16-2010, 09:28 AM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
Thanks Jaye
Old 10-12-2010, 09:16 PM
jada0327 jada0327 is offline
jada0327 is starting off with a positive reputation.
1954 F100 on what?
Hey guys, just joined this forum and just today I was looking for frames at a wrecking yard. I have a 1954 f100 cab and hood, and that's what I am starting with to build my rod. I heard all sorts of ideas, but after looking at a ford ranger the frame seams to be perfect. I was looking at 1996-97 because they looked right. The wheel base is just a little bit shorter, but i think it will work. The mid 90s models have the rack and pinion so they seem to be the most attractive. Any ideas, recommendations, considerations? Thanks
Old 10-12-2010, 09:56 PM
bj928 bj928 is offline
bj928 is starting off with a positive reputation.
the 54 i bought has an explorer axle with drums, but i'm thinking of using it on the matching trailer and replacing it with a mustang 8.8 with 4 link and air, i want the 2.73 some mustangs came with for better cruising on the freeway rather than the 3.73 or what ever the explorer 8.8 has for 0-60 and 1/4 mile times, i believe some mustangs had a 2.45 but i think that could be to high geared
Old 10-17-2010, 01:02 PM
aurkmu aurkmu is offline
aurkmu is starting off with a positive reputation.
Wink Keep the 54 frame
I heard of the Ranger swap but never heard anything good about it. You start swapping out frames it can get messy. I think keeping the same frame and working with it is a good Idea as long as it isnt trashed.
I use a 2001 explorer 8.8-31 spline 373 rear disc, its basically bullet proof and I got it for about $100, parts are fairly reasonable and it adapts well to the stock frame, I do custom air bags so it was cut and re-welded for my needs, I think you can see pics of it in my profile, I need to update with newer [pictures but you will get the picture.
I used explorer brake cables and adapted it for the 52 hand brake, used a continental drive shaft and custom made a triangulated 4 link suspension....
The trans I use is a 3 speed out of a 67 mustang, (manual)- could go with something else but it literally roast the tires flat if wanted. I cruise on the freeway pulling 3300 at 68-72mph.
Rear end parts are a pain to change after they are installed so please put in what you want the 1st time around.....Have questions just ask,,,,good luck
Old 07-26-2014, 11:22 AM
Dcommuter Dcommuter is offline
Dcommuter is starting off with a positive reputation.
I would like to learn more about using the explore springs with the axle swap. How is the ride? If not lowering the truck is the notch necessary?
Old 07-26-2014, 01:27 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Dcommuter,
Welcome aboard. Post some pics when you get a chance so we can see what you are working with. We put the Explorer 8.8in. axle & springs under our 1950 F1. If you use '97 - '01 they come with disc brakes. We went with a 2001 with disc brakes & the 3.73 gearing - it also came with a limited slip differential.
I was a little concerned that the (3) spring set up wouldn't let us use the truck as a truck but it's been fine - we've hauled all kinds of things - couches, water tanks, etc. Our truck did not have an emergency brake so we took the Explorer set up & used it as well. It fits nice.
You will have to move the shock perches - so you have to grind off the old ones. We moved a bed brace to put the shocks where we wanted it - See pic. The ride is more like a truck than a car - a little bouncy but not bad.
Looking good over there.
Ben in Austin
1950 F1
Old 07-26-2014, 09:50 PM
pholmes350's Avatar
pholmes350 pholmes350 is offline
pholmes350 is starting off with a positive reputation.
Ben, I don't mean to change the subject but what fuel tank are you using?
Old 07-26-2014, 10:18 PM
ben73058's Avatar
Hey Pholmes,
We removed the gas tank from the cab & went out back between the frame rails with a 22 gallon '70 Mustang Tank. There is a good write up on here by a user named jniolin - search & it'll pop up. I think we paid $120 through Rockauto.com for the tank & another $70 for the sending unit.
o It's not totally plug & play - you have to shave a little bit off frame rail to get it in there & build a frame for it. John Niolin has good schematics.
o Getting the Tank to talk to the Gauge was a PITA. We used after market gauges & needed a sender that used modern 0ohms to 200 ohms for Empty /Full. (We used the '70 sending unit for the fuel pick up line & soldered a universal sending unit on with the float - it works fine).
o It's really nice to get 40% more range for our truck vs the 16 gallon stock tank. You fill the tank through the Bed with this option.
Keep asking questions - lot's of knowledgeable friendly guys on here.
Ben in Austin
1950 F1
Old 07-27-2014, 09:03 AM
gas6999 gas6999 is offline
gas6999 is starting off with a positive reputation.
jada0327, checkout the explorer frame they are 1" longer than stock, most people use then already have the rack and pinion and 8.8 rear! its the only way to go!! George.
Old 07-27-2014, 12:53 PM
pholmes350's Avatar
Thanks Ben! I want to try and get the filler to the tank down behind the license plate so I dont have to fill from inside the bed. Need a tank with a fill tube that's on the back of the tank instead of on top like the mustang. I may just have to move the filler on a mustang tank.
Old 07-27-2014, 02:52 PM
ben73058's Avatar
Hey Pholmes,
You may be able to take the filler tube out the back & make it work with this tank. It's a pretty tight space between the bed wood & the top of the tank.
Here is a pic. of our bed with a marine boat filler lid installed.
Ben in Austin
1950 F1
Old 07-27-2014, 10:53 PM
pholmes350's Avatar
Thanks Ben. Very nice build by the way.
  #28
Old 08-16-2014, 04:55 AM
Thanks for your note on the explorer springs. It looks like you kept the axle on top of the springs and did not notch the frame. You mentioned a little bouncy but not bottoming out or anything. Did you use Ranger hangers like mt54? Did you shave the hangers or move the spring perch? Sorry for all the questions, I am picking up a 2000 explorer rear end and springs tomorrow so I trying to figure out the best way to put it in. Based on the advise I will also grab the sway bar and emergency brake all the way to the peddle though I would like to find a way to connect it to the pull lever in the in 56. Thanks again
  #29
Old 08-16-2014, 09:18 AM
ben73058's Avatar
Hey Dcommuter,
I'll have to take some pics of our final set up when my son brings the truck down tonight from college. Zack borrows the truck a lot to impress the college girls.
We didn't do anything with the frame. Just had to move the one bed brace to mount our shocks. There are a number of different ways to mount the shocks. The springs we originally set up over the axle but I thought the rake was too high so we flipped it to lower it a bit. Pics to follow. You'll be happy with the 8.8 - good choice.
Keep up the momentum.
Ben in Austin
1950 F1
  #30
Old 08-16-2014, 01:45 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Hey Ben,
Are you saying the explorer springs were used with the factory F1 spring hangers in their stock locations? Or did you use Ranger or other hangers?
I show the explorer springs as much longer than the stock F1 springs, 45" for the F1 vs 56 3/4" for the explorer and 2" wide vs 2" 1/2" for the explorer.
2004 explorer rear axle ? nussford Explorer, Sport Trac, Mountaineer & Aviator 3 07-26-2015 11:04 PM
Explorer 8.8 Rear End dferrell5 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 01-25-2014 02:26 PM
What rear Springs??? big schott 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 01-25-2014 01:11 AM
Will an 8.8 fit in my 1965 F100??? Waylon Fan 1961 - 1966 F-100 & Larger F-Series Trucks 16 09-01-2012 03:11 PM
8.8 installation for 1948 F1 48flthdf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-22-2012 09:56 AM
Tags
1950, 1956ford, 88, 88rearend, 89, brakes, drum, explorer, f1, f100, f150, ford, rear, rearends, spring, swap, www53fordtruckcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
