4WD LIGHT STAYS ON! - Ford Truck Enthusiasts Forums
Old 11-21-2014, 12:40 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
Print Wikipost
4WD LIGHT STAYS ON!
Old 12-16-2009, 01:44 PM
brad7.3 brad7.3 is offline
brad7.3 is starting off with a positive reputation.
4WD LIGHT STAYS ON!
Hi guys, if I put my truck in 4HI, the 4WD light comes on. But if I put it
in low range, only once in a while will the low range light come on, and it won't shift through the gears in low range when the low range light isn't
on, it just stays in first gear. Then when I put it back in 2WD, the 4WD light will stay on sometimes for more than a day. Any suggestions?
Last edited by brad7.3; 12-16-2009 at 07:13 PM. Reason: Better title and capitalized
Old 12-16-2009, 08:47 PM
Oversize's Avatar
Oversize Oversize is offline
Oversize is gaining momentum as a positive member of FTE.
sounds like the actutor on the tcase isnt properly engaging try looking under the truck at the end of the stick where the pivot arm is and see if all the bolts on the bracket are in good working order sometimes they manage to snap or come out and that can allow the bracket to turn slightly and thus when you shift ranges the bracket may move slightly and the connecting rod may not completely shift the range, and the indicator is seeing that it isnt completely shifted.
Old 12-17-2009, 12:56 AM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
The PCM uses the same wire that turns on the light to adjust the shift points on the transmission. If the light isn't coming on, the shift points will stay at the same road speed.
Old 12-17-2009, 04:14 AM
Muktown's Avatar
Muktown Muktown is offline
Muktown is gaining momentum as a positive member of FTE.Muktown is gaining momentum as a positive member of FTE.
is that only for the trucks with the electronic shift? i have the manual shift 4x4 ,my 4wd or low light never come on and my truck shifts just fine. or do you think maybe a light in the dash is bad
Old 12-17-2009, 06:45 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
A bulb is going bad or the switch in the t-case is sticking...I'll bet it's the latter.
The switch is next to the rubber hose vent line coming off the t-case.
Old 12-17-2009, 07:51 AM
Hey Cuda, about that switch, does it thread out, or do you have to split the tcase?
Old 12-17-2009, 08:27 AM
Jaaaaaaackman Jaaaaaaackman is offline
Jaaaaaaackman is starting off with a positive reputation.
Have same problem (no 4WD light or lite stays on) manual hubs/manual shift 4WD works fine just no idiot lite so I have not bothered to look more closely ,,,,,,,,,,,, could this be a bigger problem than just a lite to tell what range the truck is in????????
Old 12-17-2009, 09:42 AM
Cuda_jim's Avatar
No need to split the case, it's screwed in, be sure to check the aluminum washer. A new switch should come with it.
Old 12-17-2009, 09:03 PM
Ok, so I pulled out the indicator switch, and the ball would stick in the down position when I pushed it in. And since it's a dealer part only and no dealer within 40 miles had one, I decided to try fixing mine. I filed the end of a
paperclip down to make a tapered flat point, I pushed in the ball as far as it would go, stuck the filed end of the paperclip along side the ball and bent the clip around the switch body to hold the ball down. Used my dremel with a diamond bit to carefully remove the lip holding the ball in. Removed the ball, plunger, and spring. I had to lightly grind the plastic cup/guide until the contact tit would move freely inside of it. I put it back together, lightly peened the end to hold the ball in. It works perfectly!
Old 12-18-2009, 01:57 AM
Quote:
If the automatic transmission will shift out of 1st gear when in low range, the switch on the transfer case is working.
Old 02-16-2010, 01:08 PM
foxracing0934's Avatar
foxracing0934 foxracing0934 is offline
foxracing0934 is starting off with a positive reputation.
bringing this back to the top for Matt to see.
Old 02-16-2010, 01:30 PM
MustangMatt96GT's Avatar
MustangMatt96GT MustangMatt96GT is offline
MustangMatt96GT has a good reputation on FTE.MustangMatt96GT has a good reputation on FTE.
Thanks... I'll try taking it out and seeing what I can find.
Old 08-01-2011, 02:19 PM
bigdaddys76 bigdaddys76 is offline
bigdaddys76 is starting off with a positive reputation.
hey fellas im a frequent flyer on the 73-79 side, haveing some simular troubles with my 97 auto 4wd, auto locking, hubs, 7.3
I had to use 4wd to pull a boat out this weekend and now in the am the low range light stays on for 2.5 miles thus not allowing the trans to shift from 1st to 2nd its a shift from 1st to I assume final drive. I can drive the truck by manualy shifting on the colum and it goes thru all the gears fine.
After the first 2.5 miles and it is "warmed up" and the light goes out the truck will shift fine all day long.
Any suggestions?
Old 08-01-2011, 07:48 PM
bump
Old 08-02-2011, 07:44 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Have you crawled under the truck and looked at the linkage? Check to be sure that the bolts are good and tight on the transfer case shift linkage and that the bracket is not moving around. You can also pull the switch out of the transfer case (near the rubber breather line) and make sure it moves freely.
I'm not really sure why it would only act up when the truck is cold though. That is a bit strange.
4wd won't engage 4x4greenbeast 1997-2006 Expedition & Navigator 17 05-22-2014 01:10 PM
99 f250 low range light stays on ahoop90 1997 - 2003 F150 3 12-11-2011 10:26 PM
4wd engages sporatically bennh Excursion - King of SUVs 1 11-27-2011 04:35 PM
4wd low range light does not come on when i switch to 4wd low Snuggyworm 6.0L Power Stroke Diesel 8 08-07-2011 06:05 PM
Low Range Dash Light On nixvet2000 1978 - 1996 Big Bronco 2 05-20-2011 01:31 AM
Tags
250, 4x4, 97, drive, f150, f250, f350, ford, indicator, light, low, range, staying, stays, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
