No Limit Rack & Pinion Kit for Straight Axle - Report
i do realize the driveshaft doing the same. however, i'd think this being a more verticle shaft has to move substantially more in and out than a drive shaft. but maybe not. depending on spring rates and all. still would like to know how it "feels" running down the road. cause my next concern is attaching it directly to the axle like that, you would be more prone to vibration. i also know that ALL modern vehicle have collapsible columns and have for decades. however, they do not collapse except in case of an accident. in fact, many newer vehicle have a device that blows along with the airbags to help disperse energy from an accident. so it's not just "your" corvette js292. i am a certified I-CAR frame/suspension/steering tech. collapsible columns are due to in large part the corvair. their "straight shaft" killed a lot of people. ralph nader killed the corvair with his "unsafe at any speed" book. i just want to make a sensible choice, especially since this is my sons pickup.
The steering shaft on the No Limit kit ends up at somewhere around 45 degrees I think. So just crunching some numbers, if the steering shaft rotated upwards by 3 degrees as it followed the front axle, it would change length by 5% or so. I'd need more detailed measurements for a better number.
In any case, from my driving so far, the system is transparent. But I've not had it on the highway at speed to comment on that.
Gustave
please post your driving info when you get a chance. and thank you for your write up. this is the best way for "real world" feedback. i really like the looks and all on it. just hate to spend the $ and find out it isn't what i hoped. but at least it is a bolt on deal, so if you don't like it, it's not bad to change. it's awefully hard to go back from a stang II crossmember. can't wait to hear how it does at speed on the hwy.
I have put many miles on this same set up including a trip to Pigeon Forge this past may with no problems. Been on all types of roads at speeds up to 75 mph although i don't like to go that fast, i have had no problems. I have put over 4000 miles this summer alone and never get tired of driving the old truck.
Terry
Terry
Yeah well let me know what you think im so tossed up right now between MII 03 crown vic rebuilding the front end. Im dumping a 400 hp crate motor and 3 speed with od tranny and already order a 9 inch for it. I built plenty of Chevy's before but never had to deal with this solid front axle. Just really like the body style of the truck so im gonna adapt as best as possible. Ps no volare for me did not like the way that looked.
#29
No Limit R&P
I wonder if anyone know,s wat power R&P is bin used with the No Limit setup.Super setup actualy.Is there a Car,Truck ore Van that has a simular rack? (according to the demensions).
I,m living in Holland and for me it,s verry dificult to get parts for my 54 FFie and expensive to.Would be nice if one of you guy,s could send me the measurements from the rack.Maybe I can find a simular one at a yunkyard overhere.
Thanks.
#30
i think any rack suitable for a rear steer setup ( as in behind the axle) would work as long as its close to the correct overall width.
Threaded tie rod adaptors could be machined to offset the rack as needed.
Simple mounts to the axle also shouldnt be difficult to fabricate, and the double D sliding imput shaft is easily obtainable. Food for thought perhaps?
John
John
