You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Did you replace the fuel filter......... always do that after an injection pump change, Fill the filter with fuel or one of the fuel additives, PS white/silver, Stanadyne etc or new diesel fuel. Bleed the filter header by the Schrader valve. Open the injector lines1/2 turn from closed.
Using the starter on 15 -20 second intervals with a 2 minute cool down, close 2-4opposing injection lines at a time. It should start if you cycle the GPs after the last 4.
Thanks for the sound advise guys. Not sure where the fuel filter stands now for rotation. If it's still good [I replace it every other oil change 6-7 K] would pulling it and adding some additive be adequate or is the filter part of the process? I normally prime it with some of the diesel from the old filter and then top it off with trans fluid.
Also, FYI the CDR will not go sixteen years without service. Funny thing is I don't recall the service for it in the manual and the fellow at Ford never heard of it and traced it back as an International part number. It was a two day part so I called International thinking it would be in stock as they are high volume and heavy truck and again they never heard of it. Even with the part number he asked where it was located and what it looked like, heard him telling someone about the large tuna can on the valve cover. Always learning..
__________________
94 F350 7.3L IDI ATS Turbo 4X4 E4OD Dana 60 w/ limited slip 4:10
"Control oil and you control nations; control food and you control people." Henry Kissinger 1970
To make it real easy on your starter, Install an electric fuel pump. Ebay has them for about 45 bucks. Just cut about 6" out of the fuel line between the fuel pump and filter. Wire it so you can turn it on at will. Whenever you run out of fuel, you can prime the system by simply turning it on. Let it run for 1 hour and it will purge all of the air out of your system. Cheap at twice the price!
NEVER TOP UP THE NEW FILTER WITH OLD DIESEL....... ALWAYS USE FRESH OR AS I DO FILL IT WITH A FUEL ADDITIVE... POWER SERVICE, HAYES DIESEL TREAT, STANADYNE ETC..
You can pull the top off and fill it up, but then you have to be worried about getting it back on correctly so you don't wind up with a run away engine.
Not worth the extra work in my book.
Loosen 4 or 5 injection lines, fill the filter with fuel or Diesel Kleen and two cranking sessions it should be running.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
I always fill mine with ATF
__________________
2000 F-150 4.2L V6 2wd..........Daily Driver for now.....
1993 F-250HD 7.3L IDI E4OD 370,000 miles. Straight pipe exhaust. IP turned up 1.5 flats with a Diesel Recon pyro. 0-60 in 11 seconds. Well my rig's a little old,but that don't mean she's slow. There's a flame from her stack, And the smoke's rolling black as coal!
