'08 Ford F150 Question
Well its true...you've probably got 100 engineers testing the motors on multiple oils.....plus who knows how many more that designed the motor.....and some guy online says 5w20 doesn't matter??? I'm sick of people who think they know so much better than the guys who designed it....and base their thoughts off of what always used to be used....
Since you seem so adamant on calling me out on this, let me set you strait.
First off, Ford chose to switch to the 5W20 weight oil sometime during the mid/late-90's not because of the superior protection it offered, but to help appease CAFE requirements imposed on them by the EPA (Environmental Protection Agency). The lighter weight oil in some cases has been shown to increase mileage from anywhere from 1-3% depending on many factors (engine size, number of cylinders, gross vehicle weight, etc).
By doing this, they increase the average mileage of a vehicle in attempts to lower the dreaded "gas guzzler tax" forced upon them by the EPA. The penalty for failing to meet CAFE standards has recently increased from $5.00 to $5.50 per tenth of a mile per gallon for each tenth under the target value times the total volume of those vehicles manufactured for a given model year. In Layman’s Terms, that means the poorer the mileage, the higher the penalty imposed on the manufacturer (which is later forced onto the buyer) of the vehicle.
There are zero significant advantages or disadvantages notable from a protection or performance standpoint between a 5W20 and a 5W30 weight oil.
Next time you're at a wrecker, pop the hood on an early '90's Crown Vic or Lincoln Town car and see what kind of oil Ford recommended for them. Those old 2V short blocks were built to the same specifications and tolerances as our more recent 3-Valve engines and were fed a steady diet of 5W30 back in the day.....before EPA standard started imposing huge penalties or vehicles that craved the fossil fuels.
The recent belief that 5W20 oil is essential for maximum protection is a common misconception. I've seen modular engines that have run nothing but 5W30 Dino oil in them from day one rack up 200K, 300K, even 400K on the clock and still house their original cross hatched pattern within their cylinder walls. At the same time, I've heard numerous late model 3-valve engines sporting the dreaded top end tick with less than 20,000-miles on the clock (mine included) that had run nothing but Fords 5W20 Semi Synthetic from day one.
The difference in protection between the two oils just isn’t significant enough to warrant the worry.
So, was that clear enough, or would you care to argue the point some more? Feel free to provide some of your opposing views and facts if my explanation wasn't sufficient for you?
I do have a problem with your assumption.....are you positive the oil pumps the same as they were in the 90's? Are you sure the bearings are of the same material and tolerances? Are you positive that the alloys of the materials are the same since the mid 90's?? And if you ARE positive of all these and more things...where's your proof?
Assuming because they look the same they are the same is fine......but theres more to an engine than what it used to look like and what it looks like now.....
AND......why would you recommend that someone goes against what the engineers say....based on what you feel to be the truth?
He and I have personally had at least half a dozen Modular engines part of various displacement and valve configuration. The last of which was the engine in my Cougar which we rebuilt from scratch from the ground up with fully forged internals on the stand at home. What percentage of current modular owners and shade tree mechanics running around this site, or others can you say have done the same? To be frank, the only major variations between the engines in the family as far as tolerances are concerned are with engines running forged pistons like the '03-'04 Cobra's and GT500's where increased piston clearance is required due to the differences in the expansion rate between the forged and hypereutectic slugs.
That aside, most of the part numbers between the last batch of 2V engines and the most recent batch of 3V engines are the same. There have been different part numbers over the years because variations in the Windsor and Romeo designs and of variations between the Motorcraft and Motorsport part numbers, but for the most part...they're identical. Hell, the 4.6L 2V engine was still used up until last year’s F150 and boasted all of the same basic essential components used in the first models back in the early-90's.
Now, you can choose to take my word for it, or not (I'm betting on the latter) it's really no skin off my nose. To be honest, you strike me as the type who chooses to be skeptical unless the designer(s) themselves shows up at your door and confirm the facts for you. In any case, I'm sure you're within driving distance to your local Ford Dealership. Feel free to have them cross reference the part numbers for you. I’m sure they’ll be happy to do it.
You really don't need to take my word for it. I've got numerous sources to back my statements....pick one!
C A F E Overview
Motor Oils - Fuel Economy vs. Wear
New rules defining the cold-flow requirements of SAE viscosity grades (SAE J300) became effective in June 2001. The auto manufacturers were afraid that modern injection systems might allow the engine to start at temperatures lower than the oil could flow into the oil pump. Consequently, the new rules had a thinning effect on oil.
The auto manufacturers now recommend thinner oils for their vehicles than in the past. Years ago, SAE 10W-40 was the most commonly recommended viscosity grade, later migrating to SAE 10W-30. SAE 5W-30 is most popular now, but Ford and Honda recommend SAE 5W-20. It is likely that more widespread adoption of SAE 5W-20 and other thin oils may occur to help comply with CAFE requirements.
Because of the change in cold-flow requirements and the fuel economy test pushing formulators toward the bottom of the viscosity grade, today’s SAE 10W-30 oils are more like yesterday’s (GF-1 spec) SAE 5W-30 oils. On top of that, there is a trend toward auto manufacturers recommending thinner grades. This seems ridiculous. SUVs and trucks, with their inherently less-efficient four-wheel drive and brick-wall aerodynamics, need powerful, gas-guzzling engines to move their mass around in a hurry. In response, auto manufacturers recommend using thin oils to save fuel. Incredible!
5w20 vs. 5w30 or 10w30 Motor Oil - What You NEED to Know.
SAE 5W-20
Technical Information About 5W-20 Motor Oil
Those were accumulated with a 5-min Google search.
Y Not only are the majority of the tolerances similar between earlier and later engines, but the tolerances are nearly identical between all of the 2V, 3V and 4V varieties as well.
Oh man....again with the semantics!?! Did you read anything I posted above?
Look, if you want to debate my points above by countering them with facts and logic of your own, I'm all for it. But if all you can come back at me with time after time is "Well, the Engineers at Ford didn't tell me to do it, so I'm not going to!!!" after I not only explained my logic, but backed it with numerous examples and documentation to support my points....you're going to spend a lot of time pounding sand.
Try thinking outside the box here for a moment. Is it conceivable to you that there’s the slightest chance that Ford may have made changes to the requirements of the weight of their oil, not necessarily from best possible protection standpoint, but from a marketing angle in order to satisfy stricter CAFE requirements and in turn, turn a higher profit? I know you’d like to think Ford has everyone’s best interests at hand when they make these changes, but you need to remember that before anything else, they are after all a business.
I mean.....if these long blocks were so sensitive to minor changes in oil weight, do you think they would have increase oil change intervals from every 5,000-miles when these engines first hit the dealerships, to only twice per year like they do now?
If you want to ignore the points I've made, then that's on you....but surely common sense hasn't escaped you as well?
This is entertaining, but guys, in 1994 Ford recommended using 5w30 in my old 94 Taurus 3.0. Ive used 10w30 from day one and the engine is just as strong at 165K miles as it was back in 94. I can still get 30 MPG on the interstate driving the speed limit with the air on and still get 26 to 27 mpg back and forth to work. It still does not use any oil between oil changes (usually 3,000 mile intervals). Major repairs to date on the old girl are rear struts and springs, replace rusted subframe, 1 front wheel bearing, a couple of rear sway bar links, all new brake lines, and I'm in the process of replacing a clogged heater core. No engine oil related repairs to date. Now if Ford could just eliminate that iron moss on the quarter panels and deck lid that would be the greatest innovation known to man.
Ruin87
04-23-2012 12:33 AM
95 F150 Dude
10-04-2009 03:57 PM
