You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
A friend has two good, working, OEM chipped ignition keys. He wants to get a spare (chipped of course) and do the programming himself. I've done this on my Mazda Miata. Did a search... do these F150 PATS-II instructions apply to the '07 Expeditions??
Programming spare keys
A maximum of eight keys can be coded to your vehicle. Only
SecuriLock™ keys can be used. To program a coded key yourself, you
will need two previously programmed coded keys (keys that already
operate your vehicle’s engine) and the new unprogrammed key(s) readily
accessible for timely implementation of each step in the procedure.
If two previously programmed coded keys are not available, you must
bring your vehicle to your authorized dealer to have the spare coded
key(s) programmed.
Please read and understand the entire procedure before you begin.
1. Insert the first previously
programmed coded key into the
ignition and turn the ignition from
the 1 (OFF/LOCK) to the 3 (ON)
position [maintain ignition in 3 (ON)
for at least three seconds, but no
more than ten seconds].
2. Turn ignition from 3 (ON) back to
the 1 (OFF/LOCK) position in order
to remove the first coded key from
the ignition.
3. Within ten seconds of removing the first coded key, insert the second
previously programmed coded key into the ignition and turn the ignition
from the 1 (OFF/LOCK) to the 3 (ON) position [maintain ignition in 3
(ON) for at least three seconds but no more than ten seconds].
4. Turn the ignition from the 3 (ON) back to 1 (OFF/LOCK) position in
order to remove the second coded key from the ignition.
Your welcome.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Took me no time at all. The funny part was when I took the blank keys to the hardware to be cut. "These won't work, you know!" was their comment. "I know."
-- Chuck
I have heard that same line from the locksmith many times.
__________________
Walmart, Lowes, Home Depot and a few other stores have a Store Policy now about PATS keys. They have a scanner that checks for the RFID in the key.
Their policy is a 100% refusal to cut or copy a PATS key. Even if you offer to sign a waiver.
I ended up finding an awesome gentleman who does Locksmithing. Charged me $2.00 to cut the Fusion key/fob that I use in my Stang. And he was very well versed in the whole PATS game. I highly suggest you find a local Locksmith. They will do a better job, and not give you any crap
__________________
United States Navy - Bubblehead
2002 Excursion XLT w/ V-10 <-- The new toy
2012 Flex Limited <-- 17 mpg city, 27 mpg highway
key(s) programmed.
the ignition.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
