1999 5.4 misfire - Ford Truck Enthusiasts Forums
1999 5.4 misfire
Old 12-13-2009, 04:11 PM
twelker_04 twelker_04 is offline
twelker_04 is starting off with a positive reputation.
1999 5.4 misfire
I have a 1999 Ford F150 with the 5.4 motor . the truck has 180,000 miles on it.About a week ago it started to misfire under a load.The check engine lihgt finally came on with a code of misfire on cylinder #1.I changed the coil pack on that cylinder with no change.Then i swapped the new coil pack with another just to be safe with still no change.the misfire is getting increasingly worse and now the check engine light flashes.
Old 12-13-2009, 04:42 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
No where in your post did you mention changing the spark plug, did you change the spark plug? How many miles on the plugs, they wear out so might be time for a tune up.
Old 12-13-2009, 07:02 PM
Quote:
The spark plugs have less than 20,000 miles on them,but i will still do that just in case.
Old 12-13-2009, 09:17 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
yea, pull that plug and change.
Old 12-14-2009, 08:49 PM
fordtech08's Avatar
fordtech08 fordtech08 is offline
fordtech08 is gaining momentum as a positive member of FTE.
I've seen problems with not using motorcraft plugs and fords tend to hate bosch plugs but your problem could also be due to a bad injector or lack of compression
Old 12-15-2009, 09:26 PM
1975IH200's Avatar
1975IH200 1975IH200 is offline
1975IH200 is starting off with a positive reputation.
Use the Motorcraft double platinum spark plugs, change every 90K - 100K miles. You will have less problems in the future.
5.4 TRiton 3v code P0305, P0316 D. Shannon Rainwater Modular V8 (4.6L, 5.4L) 2 11-23-2015 09:35 AM
persistent misfire in #5 cylinder luckybarber 1997 - 2003 F150 7 07-29-2014 02:53 PM
Misfire codes: P0304 & P0305 4dkidzboo Escape & Escape Hybrid 13 01-09-2012 02:56 PM
1999 4.6 misfire edford1 Modular V8 (4.6L, 5.4L) 0 09-17-2010 08:32 PM
code P0303 darkmage55 1997 - 2003 F150 8 02-09-2010 06:53 PM
Tags
1997, 1999, 2000, 54, 97, cgeck, engine, f150, ford, lite, litre, load, misfire, misfires, misfiring, missfire, newcoilpack, tuneup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
