High torque starter
High torque starter
I have an 85 460 with the 85 starter on it. I want to put one of the newer model High torque starters on it. I know that on 5.0 liter engines you can put a newer high torque starters on an older model but you have to rewire some stuff. Can you do this with a 460 as well. What all do you have to do? What year starter do I have to have? Where can I find a wiring diagram to do this?
Google "high torque starter" and find:
Ford high torque gear reduction starter
and a host of others.
Should wire up just like your existing starter.
Yes they did. And yes you can. what you have to do is run your current starter wire down just like your current setup adn then you run a jumper wire from the big terminal that hooks into over to the S terminal on the solenoid on the high torque unit and your good to go.
[quote=monsterbaby;8235513]Bear read post 3 he says he can get it cheaper. and they do work good.
Your exactly right here monsterbaby! I've done this before on my 302 vehicles & it works great & saves your battery life as well! I guess the only question left here to answer is what size wire to make & where do I get a wiring diagram to do this because I lost the one that I had before to do it to a 302.
Eco Taxi
1999 to 2016 Super Duty
11-08-2012 10:19 AM
pipman76
05-04-2008 08:29 PM
bb78bronco
04-16-2001 09:53 AM
