Transfer case oil- Mercon V OK?
I never accused you of doing it. I was poking some lighthearted fun at a debate we had over a year ago...no offense was intensed and I honestly don't appreciate your comment.
on
No offense?.....yea right. I only ran my engine for 10 seconds to get the truck away from the pavement so I could finish the oil change and you blew it all out of proportion like it was going to throw a rod or something.
The interweb seems to indicate that Ford "transfer case fluid" is basically dexron III.
The NV271/273 was designed for dex III. Mercon V and the similar Dex VI are not very seal friendly. If you put either in a NV271/273 it will be fine internally but the seals won't hold up and it will leak. I wasn't seal guy so I don't remember which elastomers like dex VI type fluid and which don't. My advice is that although it's allegedly backward compatible I wouln't put either Dexron VI or Mercon V in anything unless it came with it.
#29
on
So do you want the information or not?
