front hub thrust washer
Old 12-12-2009, 03:02 PM
tnardo's Avatar
tnardo
tnardo is offline
my 02 f350 is missing the plastic thrust washer that goes between the hub assem and axle, anyone have the part number for this my dealer cant seem to find it on their computer
Old 12-12-2009, 03:52 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
I am not sure if you are referring to the one large thrust washer that sits against the vacuum seal or one of the three that is behind the circlip close to the outside of the stub axle. Both part numbers are listed in my needle bearing lube writeup.
Old 12-12-2009, 04:39 PM
tnardo's Avatar
tnardo
tnardo is offline
the large one, awesome thanks
Old 12-12-2009, 04:52 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
In an hour and a half, his problem was solved by the fine folks around here.
I'm in "time-out" time on the reps for you, Guzz......
Maybe some of the folks reading this, including Mr. tnardo, would care to honor Mr. Guzz with some.
Pop
Old 12-12-2009, 05:05 PM
tnardo's Avatar
tnardo
tnardo is offline
what do you mean?
Old 12-12-2009, 06:18 PM
j74250's Avatar
j74250
j74250 is offline
Would this plastic washer have flat edges on it? if so i have an extra. got a new wheel bearing and it came with a hub lock out
Old 12-12-2009, 06:53 PM
SpringerPop
what do you mean?
See in the upper, right extreme of each post, there's the word "permalink", and a red heart next to it?
When you run across a post that is particularly helpful, click on that post's heart.
The rest is pretty self-explanatory.
Pop
djmichael24951
03-22-2014 03:25 PM
Karjalanwarrior
03-24-2012 06:34 PM
Waynenap
09-02-2010 06:28 PM
lucaslaw
05-22-2010 07:10 PM
tchad07
Offroad & 4x4
08-28-2007 02:25 PM
Quick Reply: front hub thrust washer
