390 no oil at rockers - Ford Truck Enthusiasts Forums
Old 12-11-2009, 07:47 PM
4dogs4me 4dogs4me is offline
4dogs4me is starting off with a positive reputation.
I have a 71 F250 with an FE 390 no mods. Engine is a 3 year old rebuild with around 20k miles. I started noticing a clack sound coming from the passenger side of the engine. I pulled the valve cover and the rockers are bone dry. I have good oil pressure and the driver side is pumping oil like crazy. I removed the rocker arm assembly, pulled the plugs and turned it over to check if any oil would come through the oil port. None, not a drop.
I keep finding conflicting information over what to do next. Some say it is a spun cam bearing blocking the oil port and the engine needs a tear down. Others say on the FE a spun cam bearing doesn't block oil to the head.
Any suggestions/insights or guidance on what I should do or where the problem lies?
Old 12-11-2009, 08:21 PM
70sfordguy's Avatar
70sfordguy 70sfordguy is offline
70sfordguy is starting off with a positive reputation.
Old 12-11-2009, 09:09 PM
Thanks, the link was interesting but not much help.
I did find this though, oil. If I understand the diagram, a spun cam bearing would block oil to the crank not the heads. Correct?
Old 12-11-2009, 09:42 PM
70sfordguy's Avatar
Thats how it looks to me. Feeds the right side rockers first.
Did you replace the oil filter it could be faulty and restricting the volume of oil flow.
Do you have 2 pressure regulators on that block?
Old 12-11-2009, 10:02 PM
Actually it is feeding the gallery for the cam first. I am pretty sure there is a groove around that cam bearing for the pathway to the head. I just wish someone could confirm my understanding.
It isn't the oil filter (which is brand new, <2k miles). It is either a plugged oil port/passageway or a spun cam bearing, imo. Guess I will pull the head and chase down the plugged oil port idea.
Old 12-11-2009, 10:16 PM
Argess's Avatar
Argess Argess is offline
Argess has a good reputation on FTE.Argess has a good reputation on FTE.
As you can see in the pic, the passenger side oil supply is further back the main (center) gallery:
It does look like it may have something to do with the #4 cam bearing, but you are correct....it has a groove machined in the block, so cam bearing wear shouldn't totally stop the oil flow. A spun bearing should have no effect. Now if the cam bearing totally slipped fwd or aft, I can see a problem.
It's a weird problem and probably means an engine tear down. You might want to start by removing the passenger side head and doing your cranking test, but it's unlikely anything will change.
Oh....you say there are no mods, ....are you sure? If there are oil restrictors, that one may be plugged. Look down the angled hole on the rocker stand boss that supplies the oil.
Wish I could help more, but that's very weird and I can't envision the problem other than a bearing shifted fwd or aft, and I wouldn't think that is a very common problem.
Old 12-11-2009, 11:37 PM
70sfordguy's Avatar
Old 12-12-2009, 01:16 AM
Old Rusty Wrench's Avatar
Old Rusty Wrench Old Rusty Wrench is offline
Old Rusty Wrench is starting off with a positive reputation.
The FEs require that the bolts with the an under cut be installed so the oil will flow to the rocker shafts and rockers. They can be seen in the oil flow submitted by Argess. If the incorrect bolt is installed in the oil passage hole, NO OIL flow.
Old 12-12-2009, 01:18 AM
Sorry, I missed saying HEAD BOLTS.
Old 12-12-2009, 04:54 AM
Like I said in my original post, I removed the rocker arm assembly. It can't be the bolt. And there isn't a restrictor plate.
Old 12-13-2009, 08:35 PM
OrangeJuice OrangeJuice is offline
OrangeJuice is gaining momentum as a positive member of FTE.
You removed the rocker arm shaft. Did you check the oil passages top and bottom in the shaft making sure their not blocked with crud? I've disassembled mine completly and used my air compressor to blow them out. A pipe cleaner works good too. Also check the little oil holes in the rockers.
OJ
390 FE Rockers not oiling? tartar_sammich FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 06-09-2015 11:17 PM
no oil pressure? unibody62 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 31 10-15-2013 09:50 PM
Rocker oiling issue FossenRacing FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 06-04-2012 08:24 AM
1991 302 Oil problem dsc Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 11-27-2011 08:23 PM
352 no oil to rocker arms cisco47e FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 11-28-2010 03:13 PM
Tags
390, arm, assembly, fe, flathead, ford, motor, oil, oiling, problem, restrictor, restrictors, rocker, rockers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
