2000 F250 Front Drive axle and U-joint replacement - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-11-2009, 06:26 PM
timboleather timboleather is offline
timboleather is starting off with a positive reputation.
I was wondering if anyone could provide me with a tutorial or pictures or something to help me with finishing this project.
So far I have everything off the truck all the way to the axle being out.
I'm replacing the passenger side and I'm lacking seals and some bearings that were chewed up.
Thanks
Old 12-11-2009, 07:03 PM
wideglidewoody00 wideglidewoody00 is offline
wideglidewoody00 is starting off with a positive reputation.
There is a great article on changing the ball joints on a 2000 4x4 SD. It gives all the part numbers for the seals( if you have the ESOF system) and the tools you need to do the job. Just follow the steps and pictures you need to get the axle out. Hope this helps. Ford F250 F350 Super Duty ball joint replacement article.
Old 12-11-2009, 07:24 PM
thanks
thanks that site does look pretty much like exactly what I needed.
Dana 50 3.73 front inner axle seal replacement SGorman13 1999 to 2016 Super Duty 0 04-16-2015 04:11 PM
9" Rear Axle Bearing Confusion MixWizard 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-24-2014 06:23 PM
Replacing axles on a 75' F250 BobbyShane 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-06-2011 08:14 AM
Need some axle pivot bushing install help smashclash 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-28-2010 01:37 PM
How to tell what axle ratio? OpenTrackRacer Excursion - King of SUVs 17 09-26-2006 06:12 PM
Tags
2000, 2003, 4x4, ball, f250, f350, ford, front, joint, joints, removal, replace, replacement, ujoint, universal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
