bronco 5.0 to 5.4 swap?
I have an 81 bronco that has a 5.0 EFI from a 92 mustang. It is currently not running. I would like to drop in a 5.4 but I don't know if the motor mounts are the same. what potential problems could I run into in the process of doing this swap? The 5.0 motor that is in it now has a bad ring. also....one day I went to start it but it wouldn't. the fuel pump wasn't turning on and giving it any gas. I jumped the fuel pump and it works fine. could it be a computer issue?
Which 5.4 are you referring to? Are you meaning the 5.7 (351) V8 that came in the Broncos? Or are you meaning the 5.4L that comes in the new F-trucks? ('99+)
If you're referring to the newer one, that's a lot of work, since the bodies and engine bays are very different. Not to mention all the sensors and electronics that go with it.
on
There's a very good chance somebody is mistaken here and that truck actually has a 5.8 in it, it was still being produced in '97 for the HD trucks, the modular motors are completely different, and there are no "swap kits" to put one in an older truck. This would be a completely custom job with a lot of fabrication.
Unless your engine is physically broken, it would be much easier to fix the engine that's in it rather than drop a new motor in.
blake70
03-23-2012 11:17 PM
