Question on 1960s front crossmember
Im looking at a 1960 F100 with a 6 cylinder. The 6 cylinder won't do for me, I'm hell bent on a v8. I've been looking at these crossmember type engine mounts and I was curious if they get in the way of a stock crossmember? I had a 66 F100 which was easy to swap motors in, I just had to get the perches from various model trucks to mount whatever I wanted, and it had a huuuuuuuge big ol crossmember the perches bolted to. I was just curious how these crossmember mounts go in, if they get in the way of that or if they're mounted behind it, or if the older trucks even have the massive crossmember, as pictured below from the 66 I had. Pardon me if this is a stupid question as I'm not really familiar with old American vehicles...however ask me anything about an early Datsun Z and I could tell you
on
the older trucks don't have the huge crossmember like the twin beam trucks. so the bolt in style engine crossmember mount works fine.
the only problem you might run into is the rear crossmember interfering with the new transmission fit. the 60 trucks used a front motor mount (off the front of the engine) and mounts on the bellhousing to place the engine and tranny. you might have to remove the rear crossmember depending on transmission you are using and fab up a new transmission crossmember in its place.
rgds
Mike
rgds
Mike
ralphhood3
12-03-2014 04:46 PM
Old_Crow
01-10-2010 11:12 PM
Matt300ZXT
05-12-2009 06:32 PM
