Dana 60 oil rear axle - Ford Truck Enthusiasts Forums
Old 12-11-2009, 06:18 AM
bartuitschaijk's Avatar
bartuitschaijk bartuitschaijk is offline
bartuitschaijk is starting off with a positive reputation.
What type of oil should I put in my Dana 60 rear axle? It is not a limited slip. 80w90? Does it make a difference if I use synthetic or not?
It's for my 73 F-250 with 8100GVWR.
Thanks,
Bart
ps how many liters/quarts do I need?
Old 12-11-2009, 11:32 AM
zak8tac's Avatar
zak8tac zak8tac is offline
zak8tac is starting off with a positive reputation.
I believe it holds 3 quarts. I use synthetic 80w-90 in mine. Just make sure you park level and fill it up until it is level with the fill hole. Some people will park it down hill and "overfill" it, this is detrimental and will build excess heat so do not do that.
Old 12-11-2009, 12:18 PM
1979camperspecial's Avatar
1979camperspecial 1979camperspecial is offline
1979camperspecial is starting off with a positive reputation.
yup 3 quartz or six pints or 3/4 of a gallon. In this cold weather it is going to take forever to pump in. I like to jack the truck up really high on one side and remove an axle shaft then pour six pints down the tube.
Old 12-11-2009, 12:25 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Quote:
I won't even ask how you change your motor oil lol.
Old 12-11-2009, 12:30 PM
Quote:
LOL. I do that normal......I know the procedure is a little weird but I have done this enough in winter weather to know you can save about a an hour pouring it in over hand pumping it. that 90w is thick at these temperatures. In fact I just did it last week
Old 12-11-2009, 12:37 PM
Thanks,
Removing the shaft seems like a lot of work to me to, why don't you just warm up the oil in its cannister before you pump it in?
Bart
ps synthetic or regular, does that make a difference, except for the price?
Old 12-11-2009, 01:28 PM
Quote:
Originally Posted by bartuitschaijk View Post
Thanks,
Bart
I have nothing to warm a five gallon bucket of gear oil with, and I would be killed if i brought it in the house.
I would be willing to bet I can remove a axle and pour it in faster than you could pump it in by hand. It's really not that hard to pull a shaft and since I do a lot of towing of a 10,000lb trailer, i like to inspect them occasionally.
I run regular in mine. But I'm cheap. I would imagine that the synthetic is better, as it probably has better heat resistance/protection.
Old 12-11-2009, 02:43 PM
zak8tac's Avatar
synthetic vs. regular. Well I've just replaced all of my gear oil from regular to synthetic, I can tell you I notice it in the tranny and transfer case because it shifts much easier in the cold. I have not had any increase in mpg, I have not had any increase in "leakyness" lol and I will never go back to regular gear oil. I'm certain it helps during cold weather lubrication as it flows a little easier. Plus the synthetic doesn't smell as bad either.
Old 12-11-2009, 02:45 PM
zak8tac's Avatar
hahahahaha roflmao
Old 12-11-2009, 06:10 PM
jdv19 jdv19 is offline
jdv19 is starting off with a positive reputation.
I just replaced all my fluids in both my front and rear axles, tranny and transfer case. Used Lucas synthetic 80-90 in everything. I notice a big differance in the easy of shifting as well.
1979 f250 custom 4x4 dana 60 rear swap dana 70 70 Dirtyweekender77 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-10-2013 07:51 PM
AXLE SWAP QUESTIONS fordsford11 Washington Chapter 6 01-22-2012 12:41 AM
Dana 60HD rear and Dana 44 front fluid capacity kilich 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-01-2011 08:11 PM
Dana 60 axle nut size 77bigblock 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-29-2009 07:33 PM
dana 70 vs. 10.25" ford??? mustanginca 1987 - 1996 F150 & Larger F-Series Trucks 1 02-09-2008 06:33 AM
Tags
60, axle, dana, differential, end, ends, ford, limited, lube, oil, pints, quarts, rear, recommended, slip, type, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
