12V Cummins in a 99+ Super Duty - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-10-2009, 09:34 PM
Manwith3fords's Avatar
Manwith3fords Manwith3fords is offline
Manwith3fords is starting off with a positive reputation.
Anyone here put a 12V in a 99 or newer SD? I just bought a 12V engine last week and having had over 20 of the 80-96 Ford trucks I kinda want to put it in a new super duty...I have the skills to do the swap being a dealer trained Cummins engine man and license truck mechanic but I'd like to see a conversion to see how well it all fits.....My daily driver is a 91 F250 4x4 with a 7.3 IDI, 435,000KM and it runs like a clock but I want more power and it's easy to make with a Cummins.
Old 12-10-2009, 10:09 PM
rebelyell618's Avatar
rebelyell618 rebelyell618 is offline
rebelyell618 is starting off with a positive reputation.
here you go...
this is out of a excursion but it will apply for a superduty, plus a 24v but some stuff should carry over.
http://www.ford-trucks.com/forums/66...9-cummins.html
Old 12-10-2009, 10:16 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
Check out Fordcummins.com and Destroked.com
Old 12-11-2009, 05:46 AM
I've already been pricing stuff from both of those sites....I've seen the Excursion as well....Doesn't seem to be many 99+ with a 12v huh?
Old 12-11-2009, 10:36 AM
Quote:
truck wise i have seen two maybe three guys on here that have put a cummins in a superduty. Then i have seen only one ford truck in person that has had a cummins installed.
So yeah it isn't as common practice due to the work that has to been done i bet, i believe most people would just buy a diesel truck (whether dodge, ford, chevy) and save themselves the labor and time of pulling the motor and trans (then the wiring) just to install another motor.
Old 12-11-2009, 12:39 PM
Forresth Forresth is offline
Forresth is starting off with a positive reputation.
that is a factory installed engine on the F650/750 that has the same cab, so there should be no problems on the wiring side.
Old 12-11-2009, 02:01 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
I have no useful information to post on this subject...but I would be like to learn and do one myself sometime in future....posting to subscribe.
Old 12-11-2009, 04:46 PM
I have no fear of doing the swap, I'm just surprised I can't find pic's online of the 12v in a newer super duty.....I converted my 91 F250 from 2wd to 4wd, auto to 5spd and it has a divorced NP205 t-case in a custom cradle....Wicked setup with a 2wd ZF trans.....It's easy and reliable HP with a Cummins - the same can't be said for a PSD....I had a 97 F450 PSD, it worked good but it had way too much electrical to go wrong....My Cummins is going to be totally old school right down to a pull type fuel shut off.....I just need to find a cheap truck with a blown engine or trans to get me started.
Old 04-28-2011, 10:40 AM
connoisseur connoisseur is offline
connoisseur is starting off with a positive reputation.
Anyone know if a 12v will fit in a 2000 ford F250 V10
Old 04-28-2011, 11:23 AM
FoxNotch FoxNotch is offline
FoxNotch is starting off with a positive reputation.
I was always concerned about the inspection issue. I guess that depends on the state. Anyone know about NY?
Old 04-28-2011, 11:35 AM
krusterzf-350's Avatar
krusterzf-350 krusterzf-350 is offline
krusterzf-350 is starting off with a positive reputation.
It will fit, and from what i have heard its easier to swap over from gas to diesel, than from ford diesel to cummins. Its a cool swap. one I will consider when my truck gets tired...also 20+mpg on the highway would be great.
Go to this website: http://www.fordcummins.com/
Old 01-23-2012, 08:15 AM
brobrad's Avatar
brobrad brobrad is offline
brobrad is starting off with a positive reputation.
any updates
I'm putting a 12V in a 04 F350 Super Duty frame FX4, but i'm building it all to go under a 69 F350 Crew Cab. Just wanted to see if you have made any headway.
Old 01-23-2012, 09:30 AM
deck60's Avatar
deck60 deck60 is offline
deck60 is gaining momentum as a positive member of FTE.
there are several doing this swap all in different stages a few are driving theirs I hope to have mine done soon the engine trans and drive line is all hooked up and ready to go
Old 01-23-2012, 12:36 PM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
I am subscribing to this thread because i would like to learn about this for when my truck decides shes done running.
Old 01-23-2012, 01:50 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
If you search the net, ebay and craiglist -they are flooded with RV and automotive projects that sell for 10 cents on invested dollar.
OP is qualified for the job and has the engine for free (?) so he is well above the average at start. Still lot of work of love to come.
Good luck.
BTW I love inline engines like the diesel above and as the one I have in my sedan. Just to access turbo on V8 7.3 took a day of work.
1996 Ford F250, 4wd, 7.3 Powerstroke, 5-Spd Manual SHOpar Vehicles for Sale 4 07-17-2016 03:29 PM
idi ats turbo kit and engine mikey94gt Ford Truck Parts for Sale 2 11-14-2015 09:03 AM
Leather seat repair, no more worn sides 4x4EX 1997-2006 Expedition & Navigator 10 12-18-2013 03:10 AM
My battery maintainer and Marinco plug mod. ROBBINthaHOOD 6.0L Power Stroke Diesel 10 02-21-2013 09:43 AM
A Few Truck Pics... SteveBricks S. California Chapter 15 01-26-2009 07:33 PM
Tags
12v, 1999, 2007, 24v, 54, cummins, duty, f250, f350, ford, mechanics, put, super, superduty, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
