DIY Clearance Roof lights
My truck came without the roof clearance lights, has anybody installed these on there own? it cant be to hard? i did it on a old dodge but thats a pretty basic truck to do things to.
so if i buy the ford lights from edparts guy and go to put them on... is it pre wired or is it just a plug that comes with the harness i just plug into the light switch?
thanks
koboss
thanks
koboss
thanks alot Zmann, looks to me like the recon is the way to go for price and looks like it is set up for a guy like me who doesnt have them already on the roof... and you could give me some pointers .
i will call them tomorow and order over the phone, i may get a better deal by saving them the 3% that paypal charges them
how hard was your instal? what was the major part you came across
what did you do after you drilled through the roof to keep the water out etc.
thanks
thanks
well recon gives you screws but not the nylon inserts that snap into the sheetmetal after you drill the hole ,, so you need those or sheet metal screws ,, the connector that the light plugs into on the harness were never made to go together and will come loose so tape or secure those well
they have foam bases and recomend sealing ,, I don't suggest silicone ,, I would use clear latex caulk next time
ps mine had black bases because I ordered the smoked lenses ,, but they painted over chrome and had issues so I repainted those ,, I also called them and discussed my concerns so maybe they fixed the issues? either way I would still pick this over OEM
because of the smoked lenses and LED's
The led's might not plug and play in OEM? but maybe someone sells them? anyway the ground is easy just find a bolt under the headliner to grab ,,the light wire + runs down the right pillar and into the right kick panel you splice into a wire there .. if you find the instructions lacking the info let me know I will check what wire it was
