Gas tank removal
this is the rear tank where the fuel lines are there ins a special tool to take them off if u look where the plastic line stops and the metal line starts there is like a U shaped keeper on there push the line in a little and pull it out then pull the line off.....
i dont know where u are getting a $10 plastic tool because this isnt a fuel rail AND they are the same exact tank from 1980 to 1996 if u pay 10 dollars for one of those tools u just wasted time and money
These have little U-shaped clips that when you slide the fuel line on over the nipple crimp or whatever you put the U-clip into the 2 holes and it snaps into place. No special springs or anything. You can use one of those little flat head pocket screwdrivers to take it off if you wish. All you have to do is pop it up enough to get your fingers onto the clip and pull it off. Its really self explanatory.
And the plastic lines that Ford uses are just an amazing design. It takes a lot of the worry out of dropping a tank and watching that you dont kink or break rusted metal lines. You get a little more play the process.
Hey Tennessee, no fair taking the bed off. :/
Pull one of them suckers from underneath and not break anything. ;)
Now I want to know how -that's- done! LOL :)
But more important, where do me and the OP get replacements for
our broken (or soon to be broken) plastic parts?
Some say "dealer only".
Fragile little suckers, those. ;)
I've pulled three '90/'91 tanks so far and broke something each time.
Knowing full well too! :)
Alvin in AZ
ps- Cool picture, thanks. :)
pps- I'm figuring on making a hatch in the floor of my '91 Bronco.
Alvin in AZ
lol i didnt take the bed off i got that pic from google lol but when i go back to fix mine i prolly will take the bed off instead of dropping both tanks.... depends on the weather... when i dropped my rear tank i like to never got it off every thing was in the way spare tire carrier was stuck and the tail pipe is in the way lol..... but all in all its just time consuming and i would like to know where to get a new one of those little U clips too because i broke one of mine
Dorman has them, saw them @ Advance last week...
There's 2 sizes 5/16 & 3/8.( 55147- 55148)
http://www.dormanproducts.com/catalo...nal.pdf#Page=2
Try unclipping the lines from the crossmember and frame rail first, it will give you a little slack to drop the rear tank and get the lines off.
"little" is the key word there. ;)
Hmmm... seems like I got one all the way out before snagging
the hose on something, so broke it while it was out already.
Some of them have two hoses going to the vent-thing.
The vent-thing is super fragile and read here they ain't cheap.
Got any sources besides the stealership? :)
Alvin in AZ
