Help - Block Heater location - Ford Truck Enthusiasts Forums
Old 12-10-2009, 01:04 PM
B00st B00st is offline
B00st is starting off with a positive reputation.
I know that this has probably been discussed...but I find varying info on here.. I have an 01 F250... Need to find the Block Heater Plug. Just pulled both batteries out to change them, so I thought that it would be a good time to look. Let me know where the cord is located and/or if it was an option and I don't have one. I've looked (briefly) but never saw anything that resembled a plug...
Thanks in advance for the help....
Old 12-10-2009, 01:12 PM
PwerStroke99's Avatar
PwerStroke99 PwerStroke99 is offline
PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.
Go to your oil filter and look at the housing. There should be a cord coming out of it. Follow it to the front of the truck, that will be your block heater cord.
Old 12-10-2009, 01:16 PM
Thanks - I will take a look tonight when I get home to throw the batteries back in her...
Old 12-10-2009, 01:19 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
Look for the plug end around the front driver's side tow hook. It can be tucked behind the bumper. Black plug with perhaps a cover over the three prongs.
Old 12-10-2009, 01:25 PM
MTDewX's Avatar
MTDewX MTDewX is offline
MTDewX is gaining momentum as a positive member of FTE.MTDewX is gaining momentum as a positive member of FTE.
I re-ran mine up by the battery so its not in teh weather when I don't need it. ok i have to pop my hood to get to it, but its not that bad.
some have drilled holes in there bumper and mounted a plug in it with a cover. very slick adn easy to access.
Old 12-10-2009, 03:08 PM
maevans's Avatar
maevans maevans is offline
maevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud of
Here is a pic where it connects by your oil filter, easy way to tell if you have one, and like Chris said, look by the driver side tow hook.
Old 12-10-2009, 03:14 PM
mxracer3276's Avatar
mxracer3276 mxracer3276 is offline
mxracer3276 has a very good reputation on FTE.mxracer3276 has a very good reputation on FTE.mxracer3276 has a very good reputation on FTE.
Here this is where i found my plug:
Old 12-11-2009, 02:14 AM
JacksonJL's Avatar
JacksonJL JacksonJL is offline
JacksonJL is starting off with a positive reputation.
Thanks to everyone who posted info in this thread. I could have sworn my truck didn't have one. I looked all over the front of the truck, around both tow hooks, everywhere, and could not find the plug. Thanks to you guys, I went to the oil filter and saw the cord and was able to follow it up front. The plug had just fallen way down into the bumper and I had missed it before. It's been in the teens at night the last week, and although the trucks starts right up in the morning, I'm sure it will be happier plugged in.
Thanks again guys!
Old 12-11-2009, 09:57 AM
RFD_Truckie's Avatar
RFD_Truckie RFD_Truckie is offline
RFD_Truckie is starting off with a positive reputation.
While on this topic, how can you test the heater to make sure it works? I tried searching and couldnt come up with anything....
Old 12-11-2009, 12:20 PM
Justin03PSD's Avatar
Justin03PSD Justin03PSD is offline
Justin03PSD is gaining momentum as a positive member of FTE.
Quote:
Plug it in and see if it gets warm?
You can also hear a little gurgle / sizzle too if you listen close.
Old 12-11-2009, 01:56 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
I just took a ohm reading across the flat blades on the plug and got 16.6 OHMS, the resistance of the heating element plus the wiring. And like Justin said you can hear a gurgle if you listen close.
Old 12-11-2009, 10:30 PM
10-4 thanks fellas...
Old 10-07-2011, 08:30 AM
omanalansan omanalansan is offline
omanalansan is starting off with a positive reputation.
sorry guys tagging this thread
Old 10-20-2011, 11:30 PM
BrennanSpicer BrennanSpicer is offline
BrennanSpicer is starting off with a positive reputation.
I have a 1994 7.3 non turbo. I've been tryin to find the heater. I've got the cord but i just can't find the actual heatin unit. I've heard its behind the starter, on top of the oil filter housing, freeze plug. I've looked everywhere and nothin. Anyone know where it would be?
Old 10-20-2011, 11:43 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
On the IDI's I believe it is located above and behind the starter on the passenger's side of the block, might check the IDI forum for better information Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
98 F150 4.6 block heater fuse yellowsnakes 1997 - 2003 F150 6 03-05-2014 10:27 PM
Block Heater Cord Connection? hikeril 6.7L Power Stroke Diesel 34 01-23-2013 09:58 PM
engine block heater install Wisconsinman 1968-2013 Full Size Vans 3 01-15-2013 07:38 AM
Freeze Plug JO7 Escape & Escape Hybrid 0 07-25-2010 03:50 PM
block heater location mongo12 1994.5 - 1997 7.3L Power Stroke Diesel 13 12-14-2009 07:31 PM
Tags
1999, 2002, 2005, 350, 73, 73l, block, changr, f150, f350, ford, heater, located, location, plug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
