Help - Block Heater location
I know that this has probably been discussed...but I find varying info on here.. I have an 01 F250... Need to find the Block Heater Plug. Just pulled both batteries out to change them, so I thought that it would be a good time to look. Let me know where the cord is located and/or if it was an option and I don't have one. I've looked (briefly) but never saw anything that resembled a plug...
Thanks in advance for the help....
Thanks to everyone who posted info in this thread. I could have sworn my truck didn't have one. I looked all over the front of the truck, around both tow hooks, everywhere, and could not find the plug. Thanks to you guys, I went to the oil filter and saw the cord and was able to follow it up front. The plug had just fallen way down into the bumper and I had missed it before. It's been in the teens at night the last week, and although the trucks starts right up in the morning, I'm sure it will be happier plugged in.
Thanks again guys!
Thanks again guys!
I just took a ohm reading across the flat blades on the plug and got 16.6 OHMS, the resistance of the heating element plus the wiring. And like Justin said you can hear a gurgle if you listen close.
On the IDI's I believe it is located above and behind the starter on the passenger's side of the block, might check the IDI forum for better information Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
