abs brake problem
abs brake problem
I have a1988 F-150 4.9 two wheel drive 1/2 ton with rear ABS, the brake and abs light come on when the brakes are applied.Also the front brakes will lock up when coming to a sudden stop it acts like the parking brake is applied. Anybody experience this problem if so what did you do to fix it . Also how do you get the ABS codes from the truck to diagnose and does anybody have description of the codes.
these links from autozone should help they are for a 92 that I am currently working on the abs. to retrieve the codes you find the diagnostic plug it has a black wire with orange stripe mine is behind the glove box you ground out that wire with a jumper wire and turn the key to run position and it should flash out any codes
AutoZone.com | Membership Benefits
