Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
  #1 (permalink)
Old 12-09-2009, 04:56 PM
DrQuad's Avatar
DrQuad DrQuad is offline
Garage is empty, add now
DrQuad is gaining momentum as a positive member of FTE.
Detailed FICM Repair Procedure
Well I finally got around to writing a detailed FICM check and repair.
FICM pictures by DrQuad - Photobucket
  #2 (permalink)
Old 12-09-2009, 05:49 PM
1954oldred's Avatar
1954oldred 1954oldred is offline
1954oldred is starting off with a positive reputation.
Nice post!! Thanks. Sticky?????
__________________
In the end We will remember not the words of our enemies, but only the silence of our friends.
2006 F350Lariat CC SRW SB SCT X3 wID tunes Coolant Filter High Idle Mod CCV MBRP 3.5 Stainless Downpipe 4 the rest of the way No Cat EGR Delete solid up-pipe Swamps FICM Edge Insight Gauges165k. 2002 F250 CC SRW SB TS 6 position banks big head 6637 CCV 154k
  #3 (permalink)
Old 12-09-2009, 08:13 PM
barnbridge's Avatar
barnbridge barnbridge is offline
barnbridge is starting off with a positive reputation.
I know you can click on each image to increase the size but is there a way to make the images even larger? I'd like to print the images to full page size so I can print them for future use. Thanks
__________________
2004 F-250 CC, 6.0L PSD, Torqshift , 4x4, 3.73LS
ARE bedcap, bedrug; foglight/high beam mod
Coolant filter; Fumoto valve
Gauges-boost,EGT,fuel pressure
Wolverine Model 16 oil pan heater(250 watts)
Dieselsite trans filter; 2" rear, 3"front lift
  #4 (permalink)
Old 12-09-2009, 09:16 PM
DrQuad's Avatar
  #5 (permalink)
Old 12-09-2009, 10:24 PM
98SurplusExpy 98SurplusExpy is offline
98SurplusExpy is starting off with a positive reputation.
Excellent ... thanks!
__________________
2006 Ford F-250 Super Crew Lariat FX4 6.0L PSD
  #6 (permalink)
Old 12-09-2009, 10:32 PM
Chris1450 Chris1450 is offline
Chris1450 is starting off with a positive reputation.
This explains a lot to me. You have to resolder the connections is because they use lead free solder. I am a solder technician. When they went away from lead because of health concerns, the solder joints are very fragile and vibration will kill them. All electronics are suffering because of lead free solder. Thanks for the write up.
  #7 (permalink)
Old 12-10-2009, 12:26 AM
cartmanea cartmanea is online now
cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.
I buy solder with lead
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Icon springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac, Off Road Tech winch bumper
- ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost), Banks Technicooler, Garrett PowerMax VGT
Currently wrecked... again. Rebuild to come.
  #8 (permalink)
Old 12-10-2009, 07:07 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.
DrQuad...thank you! This PDF version was much easier to see vice the photobucket version. Thanks again.
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, 101k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant Filter, Raybestos PS Filter, ZooDad, HighIdleMod, BullyDog 4" (BullyDog ate Kitty), VXCF9 Strat Code, Edge Insight gauges, Fuel Press Gauge, SJ 4" Lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Diff Cover, Upfitters, Mobil1 Syn 5W-40, Stanadyne Perf, Prodigy Brake Controller, Satellite radio, Lund Moonvisor.
  #9 (permalink)
Old 12-10-2009, 07:39 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
2003 Ford F-350
Maxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant futureMaxium4x4 has a brilliant future
Added to the Tech Folder. For those of you that are not members to access the PDF version I have it downloaded to my computer.
__________________
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=209298&.jpg
John
Read First FTE Guidelines ULSD Click Here
2003 F-350 Reg Cab 6.0L
Kony 2012
  #10 (permalink)
Old 12-10-2009, 12:55 PM
w_huisman's Avatar
w_huisman w_huisman is offline
w_huisman has a good reputation on FTE.w_huisman has a good reputation on FTE.
What years do the 6.0 use the 4-pin FICM, and what years use the 6-pin FICM?
__________________
http://thumb15.webshots.net/t/75/75/8/60/86/2734860860046140835zjSXvY_th.jpg
2006 F250 6.0 Lariat
cc sb 4x4 auto 100k miles, coolant filter, FP gauge,
Edge Insight w/ EGT, AutoEnginuity, VXCF9H7 strategy
  #11 (permalink)
Old 12-10-2009, 06:39 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
2010 Ford F-150
D8chumley has a great reputation on FTE.D8chumley has a great reputation on FTE.D8chumley has a great reputation on FTE.D8chumley has a great reputation on FTE.D8chumley has a great reputation on FTE.D8chumley has a great reputation on FTE.
facebook.com/tim.burke.167
Looking at all those pics brings back fond memories from Sunday Gives me douche chills. I think the 4 pin is later 04 up, but Bismics writeup in the tech folder says the opposite. Easy to find out, just remove the small cover on the FICM and look inside. Mine had 4. BTW still waiting for my truck to be done.
__________________
~ Tim ~
If you can't stand behind our Military, feel free to stand in front of them!
'04 F250 KingRanch CC FX4 6.0 swb "BIG D"( gone but not forgotten )
'10 F150 XLT 4X4 CC shortbed 5.4 *5 Star tuned* No Bailout Edition
GO FLYERS! Go Phillies!
  #12 (permalink)
Old 12-11-2009, 07:03 AM
DrQuad's Avatar
Mine was built 6-04 and has the 4 pin.
  #13 (permalink)
Old 12-11-2009, 08:22 PM
bismic's Avatar
bismic bismic is offline
bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.
Quote:
My 2003 spare FICM is a 7 pin, so the 4 pin is the later model! I thought this is what I posted in the thread in the Tech folder, but if not .......... Good catch Tim.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #14 (permalink)
Old 01-06-2010, 09:42 PM
ke6zmy's Avatar
ke6zmy ke6zmy is offline
ke6zmy is starting off with a positive reputation.
This link goes to Powerstroke but not to the PDF. Is there an updated link?
  #15 (permalink)
Old 01-06-2010, 09:43 PM
ke6zmy's Avatar
Quote:
How might one get the PDF version?
Tags
06, 2005, 60, 60l, bypass, coolant, f250, ficm, fix, ford, location, mod, powerstroke, ranger, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
