7.3 glow plug controller install issue - Ford Truck Enthusiasts Forums
Old 12-09-2009, 10:51 AM
chewyjackson chewyjackson is offline
chewyjackson is starting off with a positive reputation.
I had a cold start issue and found (after a wonderfull burning electrical smell) that the top part of my glow plug controller burnt out.
Rather than messing with jumping wires, I simply installed a new motorcraft control unit.
Now, I have no "wait to start" light and have a clicking when the key is turned on (prior to the control unit, when the truck was working, the WTS light always came on). When the contoller was bad, I had no clicking because there was NO power to the plugs (I had to plug the block heater in to get the truck started.
The original hard to start problem I thought was glow plugs, so we installed new Motorcraft plugs. So the clicking thing shouldn't be bad plugs.
Any ideas. Is there anything in the install we could have done wrong?
So, bottom line is that I have a new controller, new plugs and the truck started this morning but it had been sitting in a garage all night long. Before the replacement of these parts, even sitting in the garage overnight the truck wouldn't start unless I had it plugged into the heater.
SEE MY LAST POST FOR THE FIX
Old 12-09-2009, 11:02 AM
87crewdually's Avatar
87crewdually 87crewdually is online now
87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.87crewdually has a great reputation on FTE.
Sounds like everthing is fuctioning but the WTS light. The plug for that on the controller is the black single barrel plug. Check to be sure it's plugged all the way in.
Old 12-09-2009, 11:06 AM
Also you should read the post at the top of this forum page that saids "READ FIRST": Glow plugs . But here's a pic obtained from that post.
Old 12-09-2009, 11:18 AM
I don't need the picture, it was removed and re-installed.
It looks pretty plug-and-play. I am just curious if I did anything wrong in the install. I should have a solid WTS light and no heavy clicking from the controller.
Old 12-09-2009, 11:21 AM
The pic is to show you the plug for the light so you can check it.
Clicking IS normal, it's called cycling the glow plugs for the first 10 seconds or so after start-up until the engine builds a little heat.
Old 12-09-2009, 01:08 PM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
just throwing in some more info from the sticky with GP help and some common sense. Did you check the continuity of the WTS light wire? how about the bulb, did you check it? What about the connections of the WTS wire? Maybe it will help, maybe not.
Old 12-09-2009, 01:30 PM
ok, i thought that the clicking was ONLY if you had a glow plug issues. That was what I was concerned about.
Old 12-09-2009, 02:11 PM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is offline
fuzzy1626 is gaining momentum as a positive member of FTE.fuzzy1626 is gaining momentum as a positive member of FTE.
The clicking should not start as soon as the key is turned on. The afterglow cycle starts after the initial heat cycle (when the wait to start light would be on).
Old 12-09-2009, 03:09 PM
Fishin76's Avatar
Fishin76 Fishin76 is offline
Fishin76 has a good reputation on FTE.Fishin76 has a good reputation on FTE.
Some where it sounds like a connection is on the wrong post on the controller.
Old 12-09-2009, 06:47 PM
Well, it's a little wierd. Let the truck sit since my last post in 20 degree weather.
It started, which means I at least have power to the plugs (which I didn't before). However, as soon as the igntion is turning forward, the clicking starts.
I had a friend remove and install it, I've only rechecked the WTS light plug and it's in the way it is supposed to. I guess I pull it back off and reinstall myself to see if he did anything wrong. Maybe a bad controller out of the box???
Old 12-09-2009, 07:57 PM
farmert farmert is online now
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Did you get the black ground wire to a good ground? Originally it was under one of the mounting bolts.
Old 12-11-2009, 01:08 AM
rechecked ground tonight. Ground is good. The clicking is WAY more than I have ever heard before. Almost 60 clicks before it finally stopped. Maybe the engine was always running in the past, and I just never heard it.
I suppose it's back to a test light to check the plugs, but that shouldn't have anything to do with why it is clicking the second I key up the ignition.
Old 12-11-2009, 01:27 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Are you sure you don't have a plug or two burnt out?
Short glow time or clicking as soon as the key is on usually indicates glow plugs burnt out.
Old 12-11-2009, 01:34 AM
I will be checking the glow plugs tomorrow. Just too late tonight to deal with it.
Still doesn't explain the no WTS light does it? The plugs are less than 3 months old and probably haven't seen 600 miles of driving. I just want to believe I spent the money on the motorcraft plugs for a reason.
When testing them, can I just use the test light method, or do i need to check with an ohm meter?
Old 12-11-2009, 01:38 AM
If they are that new, they should be fine.
What I would check is the continuity of the glow plug harness and shorts in the harness.
If the controller is cycling that fast, the light may not even be lighting.
Glow plug issues, replaced everything, still not turning off justaworktruck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-14-2016 05:20 PM
Tough WTS / GPR issue Ryanmeff19 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 07-04-2016 12:24 PM
WTS light/glow plug challenge! Ryanmeff19 1987 - 1996 F150 & Larger F-Series Trucks 2 07-03-2016 09:33 PM
Weird Glow Plug problem Forddiesel17 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 03-20-2016 09:08 PM
Glow plug problem need help! Metz12345 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-19-2015 07:48 AM
Tags
69, 73, controller, diesel, ford, glow, idi, issue, light, motocraft, plug, plugs, powerstroke, relay, start, wait
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
