95 F250 4.9 ignition problems - Ford Truck Enthusiasts Forums
Old 12-08-2009, 11:22 PM
DieselMoak DieselMoak is offline
DieselMoak is starting off with a positive reputation.
I sure could use a hand with this one. I have a 95 F250 4.9 with MT. The truck just quit. I'm not getting any fire from the spark plug wires. I tested the coil and it passed. I tested the module and it passed. I replaced the stator because i didn't know how to test. I am still not getting any fire, nor ground break at the coil. What now???????
Old 12-08-2009, 11:35 PM
88n94 88n94 is online now
88n94 is gaining momentum as a positive member of FTE.
Do you have power to one of the small terminals on the coil with the ignition switch turned ON? If you do I would go ahead and replace the coil anyway even though it tested good.
What do you mean you're not getting any ground break at the coil?
Old 12-08-2009, 11:43 PM
I have power to both coil terminals. With a test light i probed the tach side of the coil, then turned the engine over. If my ignition components were jiving then the test light should have flashed as the engine rotated, indicating the intermitent power break from the coil.
Old 12-09-2009, 12:03 AM
I don't think you should have power to both small coil terminals. The one side just goes to the distributor. I wonder where that power is coming from?
Old 12-09-2009, 12:13 AM
Beats me ?!?%(#%&)(#
Old 12-09-2009, 08:58 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Power on both sides is what you want. The power on the tach side comes through the coil.
Unplug your computer and see if the spark returns.
Old 12-09-2009, 11:46 PM
Unplug the computer or the module? Thanks
Old 12-10-2009, 06:46 AM
subford's Avatar
Unplug the PCM Computer.
You can also unplug the SPOUT jumper sometimes but if the IDM input in the computer is bad this will not help.
So it is best to just unplug the PCM Computer.
You need the ICM (Ignition Control Module AKA TFI) for the spark but you do not need the PCM Computer for spark.
The PCM Computer can stop the spark from happening.
The engine will not start with the PCM Computer unplugged as the injectors will not fire. But you could spray starter fluid into the intake and it may fire with the PCM computer unplugged.
Also note that bad wiring from the PCM Computer plug to the ignition system can also stop the spark also if it is shorted to ground.
Old 12-13-2009, 02:34 PM
You were right on the money. I unplugged the ECU and spun the engine over and i had fire. I sprayed a little starting fluid in, spun it over again and it cranked. WOW.......... yall really know your stuff arround here. I appreciate all the help, and maybe i can be of some help to yall in the future. I'm a diesel man for CAT. I only work on engines. I also work on alot of 7.3's on the side. Hopefully i can contribute. Thanks again
Old 12-13-2009, 07:06 PM
subford's Avatar
Sounds like you have a bad PCM (ECU) computer then.
What should I do next jefrow03 Ford Inline Six, 200, 250, 4.9L / 300 10 03-21-2015 02:39 PM
85 f250 6.9 idi trans question redneck201383 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 11-17-2014 09:33 PM
87 f150 4.9 badger27 1987 - 1996 F150 & Larger F-Series Trucks 0 09-09-2014 06:38 PM
4.9 Exhaust Ideas: Y-pipe 732t37 1987 - 1996 F150 & Larger F-Series Trucks 3 01-25-2012 05:10 PM
Can I remove catalytic converter from 95 F250? lukaspriest 1987 - 1996 F150 & Larger F-Series Trucks 1 05-24-2010 03:06 PM
Tags
250, 49, 95, 95f250, check, computer, engaging, f150, ford, icm, ignition, located, pcm, power, problems, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
