Details....Ford's new 6R140 Six-Speed Heavy Duty Transmission - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-09-2009, 05:45 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
They use a fine metal powder squeeze it under somewhat high pressure in a die to form the shape. (Sintering is NOT forging) The powder has a binder in it so when its sintered (heated up to high temp) it binds together. Powdered metal parts are OK but I wouldn't make gears out of it which are under a lot of stress. Would be better off hobbing the gears and then heat treating them but that costs quite abit more than a powdered part. A gear machined from a forging or a solid piece of stock would be a lot better. Tungsten carbide inserts common in the machining industry is a good example of a powdered metal part.
Brazing is more of a term that describes a heat range. For example once you get over a certain temperature you are no longer "Soldering" a part together you are now "brazing" it together. You can braze brass, copper, steel cast iron and etc with the same low fuming bronze brazing rod and a oxyfuel torch.
Old 12-09-2009, 10:00 PM
dstig1 dstig1 is offline
dstig1 is gaining momentum as a positive member of FTE.
PM is heavily used for gears. That is one of it's strongest applications.
Machining from solid stock is often not as strong due to grain structure issues. For a related example search the interweb on rolled threads vs cut threads.
Many parts that are sintered are also infiltrated with a lower melting metal to fill in the remaining interstices in the PM matrix.
Tungsten carbide is sintered, but is not PM as it is a ceramic. Similar process, but yet different.
PUTC: 2017 Super Duty Details Rambo 3 2017 Super Duty 185 03-24-2016 08:22 AM
2017 Super Duty Debut Texas State Fair in September Troy Buenger 2017 Super Duty 41 09-23-2015 10:30 PM
Did you hear about the new 6.8L V10 Rosson03 Excursion - King of SUVs 37 02-18-2012 08:41 AM
What does this mean? 76f350spercamprspeal 1999 to 2016 Super Duty 5 03-31-2010 04:41 PM
New engine info....6.2, Ecoboost.... powerstroke72 2009 - 2014 F150 24 03-18-2010 11:53 AM
Tags
4r100, 6r140, 73, duty, fit, fleetwood, ford, heavy, retro, specs, strong, swap, transmission, transmissions, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
