SRS Code 46
This is about all I could find on the code 46.
It seems to have to do with high or low resistance in the drivers side seat belt tensioner sensor, or the system having recently been disconnected with the vehicle power on. If the latter was the case & the computer doesn't detect another problem after something like 256 start cycles, the SRS computer will finally clear the code & turn the light off.
OR, you could disable your fuel pump, so it wont cycle on, & turn your ignition key from off, to run, without cranking the engine, enough times (256) & it'll clear the code & turn the light off.
OR a Dealer, or shop with a scantool that'll access the SRS system can do it.
Let us know what you find.
Ok. so i got to looking at the drivers seat today. I found why i have the SRS code. The PO ripped the connector right off the harness. Both sides are missing(seat and truck) I am Just going to but connector the wires to their respective match. Does anyone have a pic or diagram of where they go? I would like to get the truck inspected, and its a no go with the SRS on
If your '04 is the same as an '02, then here's what you're looking at:
Pretensioner Connector
Pin 1 = (BK) Ground
Pin 2 = (LG/BK) Driver safety belt retractor pretensioner, return
Pin 3 = (BN/LB) Safety belt buckle switch (10B924), input
Pin 4 = (LG/RD) Driver safety belt retractor pretensioner, feed
Pin 1 eventually gets grounded to the vehicle floor.
Pins 2 & 4 run to the Restraints Control Module (pins 22 and 18, respectably).
Pin 3 runs to the GEM (pin 5)
Pin 1 = (BK) Ground
Ok, I'm back at this again since I am FINALLY putting the truck together after pretty much a frame off resto
The seat side harness has ..
(2)red /white tracer
(2) black /white hashes(at least thats what it looks like)
And no connector
The truck side...
red
red /green tracer
red /black tracer
Black
Suggestions on how to connect them?
And no connector
The truck side...
red
red /green tracer
red /black tracer
Black
I searched in my 2004 shop manual, and let me tell you, they don't make it easy to find anything. There's lots of chapter headings that are just numbers and the only way to find anything is to open every page. I found the connectors for the belt sensors, so I hope this is what you need. Let me know if I can help more. I think I'm slowly learning how to navigate this mess.
I actually found someone with an 04 that was able to give me the color to color match.. I'll post my results in the AM
But thank you VERY much
RW1998
1997-2006 Expedition & Navigator
43
01-23-2016 04:57 PM
saltydog463
01-19-2016 09:12 AM
