rattling sound - Ford Truck Enthusiasts Forums
rattling sound
Old 12-08-2009, 04:06 PM
19expy97's Avatar
19expy97 19expy97 is offline
19expy97 is starting off with a positive reputation.
rattling sound
Need help on a rattling sound that is happening on my 2006 f-150 screw 5.4 only mods are volant cold air intake and cat back exhaust. Sound seems to be coming from passenger side foot well compartment. Its sounds like a spark knocking or tinny sound only when engine is under load . First experiance it when od is off and im pulling a hill with my trailer, Now i seem to hear it when truck is in od and climbing a hill when the rpms go down before it kicks down . This noice is really annoying sounds like the truck is going to come apart. Any help would be greatly appreciatted
Old 12-10-2009, 10:06 PM
hillbilly1955 hillbilly1955 is offline
hillbilly1955 is starting off with a positive reputation.
I have a 2001 F250 super duty that resembled exactly what you describe, supossedly there is an access panel somewhere on the flywhell cover and it slipped in and is dragging on the flywheel might be the same problem.
Old 12-11-2009, 11:06 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
Sounds like detonation or lean condition to me. See if it has any codes such as lean or misfire. If that's the case, get that Volant off of the truck until you can get a programmer with custom tunes that'll fatten up the fuel curve enough to get the A/F ratio back where it should be. Detonation eats platinum plugs and can ruin a perfectly good engine.
Old 12-12-2009, 10:26 PM
sandrat's Avatar
sandrat sandrat is offline
sandrat is gaining momentum as a positive member of FTE.
Torque Converter rattle maybe? The automatic hubs will make noise too when load increases, the actuator solenoids go bad and you'll get vacuum present at the hubs all the time, so when the engine increases rpm and you lose vacuum to the hubs, they'll make weird noises, sounds like a spark knock sometimes.
Old 12-13-2009, 03:53 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
Any time someone describes noise under low intake manifold vacuum conditions, I think IWE's. Mine sounded like barbed wire wrapped around the front drive shaft.
Old 12-15-2009, 04:22 PM
19expy97's Avatar
Cool
hey thanks all for your help, just to add one more thing this sound does not happen from a standing start (wot) nothing sounds out of the ordinary . Will try pulling intake this weekend and see if any thing changes . Intake has been on a year and a half and this noise has just started happening. First noiced it pulling the trailer but not notice it on a hill ( not even a big one) when the motor is working hard in over drive and really seems to be getting worse by the day
Old 12-15-2009, 07:57 PM
Be sure to check for codes as well.
Old 12-16-2009, 11:45 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Heat shield? Or debris stuck behind the HS?
Old 07-15-2011, 03:35 PM
Ron2006F150 Ron2006F150 is offline
Ron2006F150 is starting off with a positive reputation.
Rattling noise 2006 F150
What was the outcome of your problem. I have the exact same issue and the same mods done on my truck.
Quote:
Old 07-15-2011, 06:19 PM
VFR_Man's Avatar
99% probability it was the IWE's as it probably is on yours.
Old 07-22-2011, 07:08 AM
triple8 triple8 is offline
triple8 is starting off with a positive reputation.
my truck is doing this, again. it did it awhiile back and then stopped. what is an IWE? also no lights on the dash, will it still throw a code if you do not get a warning light on the dash?
Old 07-24-2011, 11:33 PM
My problem was a vacuum leak between the IWE solenoid and the IWE actuator. Search on IWE and you will find plenty of info on it. Thanks to all the info it was a pretty easy fix and saved me plenty from not having to take it to the shop! It is the 4WD hub locking system.
Old 07-26-2011, 06:50 AM
i believe i confirmed that my noise is my IWE today. driving to work with the window down heard the rattling and flipped the 4X4 on... noise immediately went away, shut 4X4 off and reapeated a couple more times. every time i flipped the 4X4 on the noise stopped.
now i need to inspect, or thought about just replacing, the vacuum lines before getting into changing the entire unit.
i love this site. great information!
thanks everyone
Old 07-27-2011, 12:32 AM
I had a pretty easy fix. I bought a vacuum pump/tester at the parts store for $40. Tested the first line down from the solenoid to where it branched to both actuators and the leak was there. Seems like the trucks can keep the vacuum good enough to overcome the leak until a heavy enough load on the engine and then then not enough vacuum and you get the rattling sound. Good luck!
4.6L Engine Rattle when accelerating. morris_506 1997 - 2003 F150 9 01-15-2017 10:46 PM
Rattle on Acceleration hermannm2 2009 - 2014 F150 4 05-25-2016 09:45 PM
F150 5.4L strange rattling noise, PLEASE HELP, I need a idea!! Sweetrocks Modular V8 (4.6L, 5.4L) 46 10-05-2015 03:40 PM
2008 F150 Mystery Rattle dogshack 2004 - 2008 F150 2 10-15-2014 01:14 PM
TC lock up switch at idle stimy2001 1999 - 2003 7.3L Power Stroke Diesel 41 10-06-2013 03:51 AM
Tags
2000, 2007, 54, area, converter, f150, ford, knock, knockrattling, load, noise, rattling, sound, sounds, spark, tinny, torque, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
