Volare Front end Power steering
Hello Anders from Sweden.
I wonder i anybody can help me. i have change front end to Volare in my F-100 -56 my qestion is.
Whan power steering pump i should use i have one from Volare and one from orginal Y-block (Mercury)?
The different is on Volare the power is in the steeringgear and Mercury have a power cylinder.
I hope you understand what i mean.
Anders
Anders
Can you find the PSI output for the Mercury pump on the internet? It may wrok. The Volare box PS does not require as much pressure as many others. I am running a Ford PS pump on my Volare box, but it is from a true PS sustem, not a power assist clnder. Mine is definitely a little fast and soft, but has worked fine for 5 years? The Volare pump you have will work perfectly of course.
on
It will take a little fabrication but I'd use the Volare PS pump if possible. It will work best with the box you have. I have successfully fabricated brackets for both a 350 Chevy and a 302 Ford to run a Volare box. I'm sure getting one to work with your Y-block can also be done with a little work...
