2 to 4 inch lift
Suspension or Body Lift?
If you do suspension lift it's going to cost to do it right.
My suggestion if you want easy and good value for the money put a two inch body lift and then get some 35" tires my guess is that will lift your truck up 4" or 5" and let's you keep the stock suspension.
Just remember your brakes and steering are still stock and a lift and bigger tires are harder on your truck.
Maybe 33" or 31" tires will satisfy your need for height, they're also cheaper than 35"
I guess it all depends on your application, if it's for off road then bigger can sometimes be better, if it's for hwy then higher can be less stable and more dangerous at higher speeds.
None of these ideas are recommendations, just my thoughts on the question asked.
Rick.
christop43
11-22-2002 06:54 PM
