comp cam valve springs...
on
Comp Cams 910-16 Comp Cams Single Valve Springs are these the right ones i'm looking for my truck??
WOP High Performance Valve Springs, will help elliminate valve float in high boost and high RPM situations. The kit includes Dual valve springs, steel retainers, valve seals, billet keepers It also Includes valve seal cutter, and 5/16th pilot. All you need to do is cut the valve guide seal with the tool provided using a hand drill. Dual Outside Diameter of Outer Spring (in): 1.440 in. Coil Bind Height (in): 1.110 in. Spring Rate (lbs/in): 340 lbs./in. Inside Diameter of Outer Spring (in): 1.085 in. Inside Diameter of Inner Spring (in): 0.795 in.
I compared specs on WOP's springs and comp cams and they are very similar.
Is there something I am missing here?
The only difference I notice is comp cams are "Single Valve Springs" while the WOP's are "Dual Valve Springs"
Is this what makes a difference?
Macrobb
16
03-07-2016 03:00 AM
mueckster
37
08-22-2013 09:25 PM
MONAVIERONJON
06-28-2013 08:21 PM
69Cobra
08-01-2012 05:27 PM
